Hello every body. I have a Mini2440 with 128MB Nand-Flash and i'm going to build my WinCE6-R3 image for that. First try result is that RAMIMAGE and RAM sections of defined memory is in overlap state and i changed the Config.bib to increase my RAMIMAGE. the build errors were solved and NK.BIN file was generated. Now i have OEMVERIFYMEMORY error in downloading my image to the device. the CE6-R3 PB is updated to 2010-11. Supervivi is latest update. has any body same problem? how solved? is this supervivi's problem? Thank for advice.
OEMVERIFYMEMORY Error again after updating supervivi
Do you have installed the last SuperVivi in NOR and NAND? There are also already topics about this http://www.friendlyarm.net/forum/topic/235 http://www.friendlyarm.net/forum/topic/1082
