I modify the MEMORY section of the config.bib file to make more room for
the Windows Media Player and codecs.
The new section is now:
MEMORY
NK 80200000 02600000 RAMIMAGE
RAM 82800000 01600000 RAM
; FLASH 92000000 00100000 RESERVED
The "solution" compile OK, but I'm not be able to download the nk.bin to
the board.
This is the error message from "DNW v0.50L for wince":
Download Address=0x80200000 Length=0x20cc43c
BIN image type unknow
!OEMVERIFYMEMORY: Invalid image
Where am I wrong?
TIA
Clemente.
OEMVERIFYMEMORY error
I did another test, I modify the CONFIG sectionn of the config.bib file
adding the AUTOSIZE keyword:
CONFIG
AUTOSIZE=ON
The output of the compilation is now :
Pass 2...
RAM AutoSize: RAM Start=822d0000 RAM Size=01b30000
Found pTOC at 0000156c
But when downloading I receive the same message!
Is a supervivi/nboot problem?
TIA
Clemente.
Hello to all, I'm in stuck with this problem. I'm be able to compile an nk.bin files but the supervivi seams to reject the new file, because is not inside 32MByte I think. Searching the Internet for a solution I found this very very interesting site [1]. With some very usefull articles and snapshots about SilverLight technology [2][3]. Very beautiful!!! So please let me know if someone is jumping out from this problem. Or if I'm wrong somewhere. :-) TIA Clemente. [1] http://discovertheexperience.blogspot.com/ [2] http://discovertheexperience.blogspot.com/2009/10/windows-embedded-ce-60... [3] http://discovertheexperience.blogspot.com/2009/10/windows-embedded-ce-60...
I had this problem befor. SuperVIVI not support wince 6.0 image I download the image of wince 5.0 from: http://www.andahammer.com/Downloads/mini2440-en.rar and it work fine
Hi, www.arm9.net has updated the software, include the complete windowsce6 bsp, and the new supervivi. hope it is helpful. mindee
Hello mindee, thank you for the info. I just recompile in inglish the image, without adding new packages. But: are you sure that this is a new version of Supervivi? It has the same date and the same size as the previous one found in the wince6 mini2440-20091130pre package. Clemente.
I do have exactly the same problem.
I have Mini2440 with 1GB and i use supervivi-128m dated 11.11.2009
i tried
MEMORY
NK 80200000 03C00000 RAMIMAGE
RAM 84000000 03C00000 RAM
and my image compiles fine. but when trying to get the nk.bin (33mb) to the
mini2440 i get a OEMVERIFYMEMORY error
is there any solution?
Hey Guys! Just try downloading the RELEASE build (not DEBUG!). If it works out less than 32 MB in size, I guess it will work fine. Mine did! Good luck! Gautam
