I program file \images\2440test\2440test_L80.bin on NOR Flash(mini2440 LCD-L80) by H-JTAG after that I can not program file on NOR Flash and error "Flash id does not match". How?
can not program NOR Flash
I change switch to NOR and I program file \images\2440test\2440test_L80.bin succcess (before program file 2440test_L80.bin on NOR Flash I can program on NOR Flash but after program file 2440test_L80.bin I can not program on NOR Flash)
I try switch to NAND then back to NOR. I click "check" have error "Flash id does not match.. Please make sure that the right flash device is selected."
Hi theerapong, Please check out my answer to Marco's similar problem here: http://www.friendlyarm.net/forum/topic/874 I think that should solve your problem too! Good luck! Gautam
I working by H_JTAG and program NOR Flash successfully but one time i erase NOR Falsh by click in "Erase" button then i can not program NOR Flash. When i press 'Check" or "Program" button show this error message: "Can not download driver to specific address" plesae help me.
