Linux 2.6.32.2 (2010-01-13) 81 MB from http://www.friendlyarm.net/downloads when compiled gives an image of size 2.4 MB (2517072 bytes).It doesnot load on my 128 MB board?? which ones the problem?? -My 128MB board or -Should the zimage size be less after compilation?? thanx, kevin
kernel image
2.4MB sounds about right for the default kernel. Can you successfully re-install the default images that came with the board?
yes if the image is less than 2 MB it loads.but with 2.4 MB it says kernel size exceeded or something like that
The size allowed for the kernel on the 64M board is 5,242,880, would expect the same or bigger for your board. Someone else?
Use part in supervivi to modify the partion sizes: http://www.friendlyarm.net/forum/topic/541 http://www.friendlyarm.net/forum/topic/661
