Hi guys, I wanted to update to the latest kernel and root image found on this website. I downloaded them but when I go to load the zImage with supervivi, I'm told that the zImage file is too big: Enter your selection: z USB host is connected. Waiting a download. Length of file is too big : 2517028 > 2097152 Failed downloading file Effectively its true, its 2.5 Mb as opposed to the kernel partition which is only 2, so I tried to manually resize the partitions with supervivi's "part" command. Although I create a 2.6 Mb partition, upon trying to load the zImage, I still get the same error... Can anyone help me? thanks a mil Paul
zImage file too large
hi, you have to update the bios in NOR flash first. the latest bios is supervivi-0945 regards mindee
Hi, sorry but this doesn't work. I've downloaded the supervivi_20091110 from the download section and j-tagged the 128 onto my mini2440. When I connect I see [i] Version: 0945-2K But when I upload the latest zImage file I still get the same error Enter your selection: z USB host is connected. Waiting a download. Length of file is too big : 2517028 > 2097152 Failed downloading file Is there a different version of supervivi somewhere I'm missing? Or is the -2k on the name an indication of the kernel partition size? Thanks a lot Paul
Paul, Is it ok for you to use SD CARD for booting? Installing u-boot and loading uImage from SD CARD has worked for me. My kernel is also hugh becoz i have added, ext3, ACM, SYSFS, NTFS etc? Though I have not tried putting uImage in flash, I dont think that will be a big problem. With you boot you can easily change your environment and partitions. Regards, Vikas
Actually I guess I can... But I need the full functionality of the new kernel + camera modules etc. In other words I would love to run the default os + fs of the sd. I've converted the new kernel image to uImage from zImage, that was ok. Now I need to get the fs onto the sd card. How can I access the files inside the img file? Can anyone suggest a solution? Thanks Paul
unyaffs for yaffs(2) images. Otherwise mount it with -o loop. Booting a root-fs from SD-Card is very very slow... A full blown gentoo needs about 4 minutes from power up to login. A Debian takes about 3.5 Minutes...
Hi Paul, try first to shrink the kernels size. In the default configuration are good reserves. What you can drop: nfs, chinese code page, if you do not use modules uncheck this too. These things bring good savings in kernel size. If you drop chinese code page you have to change the default for vfat file system. skip
Hi Paul,
I've been struggling with the same error in the past few days too. But I
solved it. Looks like you are going toward the right direction by resizing
flash's partition. Try to give larger trunk to the kernel using part
command. And make sure YOU SAVE IT by "part save"!
This is how my partition looks like:
Supervivi> part show
Number of partitions: 4
name : offset size flag
vivi : 0x00000000 0x00040000 0
param : 0x00040000 0x00020000 0
kernel : 0x00060000 0x00500000 0
root : 0x00560000 0x40000000 0
You make encounter other errors like "Failed to execute /linuxrc ...". If
so, drop a post or give me a buzz!
Hi Honeybee That's exactly what I did :) When I resized (I resized to 600000 which should be enough) I then offset the root partition by 100000 and save it alright. When trying to upload it complained again about the partitions. I'm not sure why... if anyone has done this successfully, can they let me know? Thanks Paul
Nils, sorry but I can't mount it, is says fs type not recognised, also unyaffs doesn't work for me, says its not a recognised image. I've been trying to compile the latest source for qtopia2.2.0 from this website but it fails when compiling tslib for qt2 I'm exhausted by all this :P Been working on it for ages, just wish I could get a working updated fs... Please help!! Thanks Paul
Hi Paul, With my partitions as what I posted, I successfully burnt the kernel image into the Flash (kernel partition). So I'd recommend you to try exactly my partition layout and see what's happening. I think this is related to the kernel's MTD driver. I'm still looking into this. But if you like, take a look at the this file: .../linux-2.6.32.2/arch/arm/mach-s3c2440/mach-mini2440.c. You can tell that I partition exactly as friendly_arm_default_nand_part[] in this file. I don't know how they are co-related at the moment, but for me it's working ...
Hey Honeybee, so your partshow is as it is above? Do you still use DWN to upload the files or have you put u-boot in its place? Thanks Paul
Yes, the above partitions are from "part show" command. I use DNW to download the image (and bootloader and rootfs). I'm still using supervivi from NOR for all the operations.
God I'm such an idiot!! I got it working... rather than chose the option "upload zImage" on DWN I should have been selecting "upload kernel file" damn!!! Thanks a lot Honeybee, case closed. Back to Qt now :P Paul
Hi I have the same error: Length of file is too big : 2517028 > 2097152 How did you do for working ? Did you resize the partition ? Which is the part command ? Thanks
WOW u guys are so intelligent, i dint get one thing. one post above PAUL
said -
"I got it working... rather than chose the option "upload zImage" on DWN
damn!!!
Now where is this "upload zImage" or "upload kernel file" option in DWN
i only have these tabs at the top->
1.)serial port -connect
-transmit
2.)USB port - Transmit/Restore
-backup nand flash
-status
3.)configuration -option
4.) Help
HELP!
This is a option from supervivi (FriendlyARM BIOS). Read the download manual: http://www.friendlyarm.net/dl.php?file=download.pdf
okay done.i dont need to have those options.actually i didnt save part save so the problem..sorry
Honeybee, you said: "You make encounter other errors like "Failed to execute /linuxrc ...". If so, drop a post or give me a buzz!" I am getting this error after taking these steps: 1)delete kernel and root partitions 2)add kernel partition with size ~3meg 3)add root partition 4)load a customized kernel of mine (~2.4meg) 4)load the friendlyarm-provided qtopia filesystem The kernel loads fine, then I get the error you mention. Any ideas?
Honeybee,
But when i power on my mini my screen was stopped!
Honeybee, I found this error "Failed to execute /linuxrc ..." like you said. So , what do i do now ? Thanks
Hi all, Now the problem is solved. On DNW do (after to parted flash like the Honeybee said): [q] 1) Supervivi>param show 2) Supervivi>param set linux_cmd_line "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0" 3) Supervivi>param save i hope help all
I have the param right (noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0) but still get Failed to execute /linuxrc ... error does anybody has an idea?
I would like to know if there is a max size of zImage. I've compiled this kernel with the original configuration and it work's fine! But when I added more support into the kernel (bluetooth and wireless drivers for example) and his size increases of 2,16Mbytes for 2,38Mbytes, I can't write the zImage into the mini2440. Someone know why? Error: Now, Downloading [ADDRESS:30000000h,TOTAL:2480730] RECEIVED FILE SIZE: 2480730 (605KB/S, 4S) Downloaded file at 0x30000000, size = 2480720 bytes Found block size = 0x00260000 Erasing... ... failed There is no message "Length of file is too big" My flash memory have 256Mbytes and I'm using supervivi. Supervivi> part show Number of partitions: 4 name : offset size flag ------------------------------------------------------------ vivi : 0x00000000 0x00040000 0 param : 0x00040000 0x00020000 0 kernel : 0x00060000 0x00500000 0 root : 0x00560000 0x3fa80000 0
In the past I was able to download using supervivi and dnw without any problems. But lately I tried to change the output port of my debug console from ttySAC0 to ttySAC1 using the supervivi options as follows: [s] Set the boot parameters [s] Set parameter Enter the parameter's name(mach_type, media_type, linux_cmd_line, etc): linux_cmd_line Enter the parameter's value: "noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC1" After saving my changes I got the same error as Andreo. Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Backtrace: [<c0035270>] (dump_backtrace+0x0/0x10c) from [<c03958f0>] (dump_stack+0x18/0x1c) r7:00000000 r6:c0503ed0 r5:c0503660 r4:c04c61a0 [<c03958d8>] (dump_stack+0x0/0x1c) from [<c0395940>] (panic+0x4c/0x134) [<c03958f4>] (panic+0x0/0x134) from [<c00305a4>] (init_post+0xec/0x178) r3:00000000 r2:c3954200 r1:c0539000 r0:c045348c [<c00304b8>] (init_post+0x0/0x178) from [<c00084c4>] (kernel_init+0xf4/0x124) r5:c00205d4 r4:c00205d4 [<c00083d0>] (kernel_init+0x0/0x124) from [<c004d1a4>] (do_exit+0x0/0x62c) r7:00000000 r6:00000000 r5:00000000 r4:00000000 I thought I would reflash the device to get rid of this error. This is when I started getting the: Length of file is too big : 2517028 > 2097152 error. I suspect these two problems may be related. I have a backup of my binary image, so I will attempt to restore that next. So basically, it seems that the solution given by unknowN is what creates this problem in the first place. James
After redownloading my original .bin backup file, the board boot fine. This tells me there is nothing wrong with the board itself, or its flash. However, I still cannot download my zImage file. My technique is as follows: 1. Open dnw.exe 2. Place s2 into Nor position. 3. Power up board (with cables attached) 4. In dnw serialport->connect (Hyperterminal works just as well) 5. Configuration->Options baud 115200 Download address: 0x30000000 6. x to format 7. v to download supervivi - file: supervivi-128M 8. k to download linux kernel I have the 3.5" TFT screen so I will try the zImage_N35 file (they are all the same size). USB host is connected. Waiting a download. Length of file is too big : 2517028 > 2097152 Failed downloading file This seems to contradict my previous statement that the problem was related to my prior attempt to change the console port, but still does not explain the fact that the procedure worked perfectly in the past. James
hi All, I followed all the steps listed above but still i am not able to flash 2.6.32 kernel onto my S3c2440 :(. I made the partitions as suggested above (as suggested by honeybee) and below is the snap shot of it. I did a try both in windows and linux to download the zImage but no luck. Vivi Throws the same error "Length of file is too big : 2288308 > 2097152 Failed downloading file" My part show snap shot: ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi Enter your selection: q Supervivi> part show Number of partitions: 4 name : offset size flag ------------------------------------------------------------ vivi : 0x00000000 0x00040000 0 param : 0x00040000 0x00020000 0 kernel : 0x00060000 0x00500000 0 root : 0x00560000 0x40000000 0 Supervivi> Please let me know if i am missing some thing.
hi All, BY deleting some partitions and re-trying again i am able to make my S3c2440 to boot with the latest 2.6.32 Kernel (which i have downloaded form this site). Thanks for this support. I had another s3c2440 with 64MB flash and to run it on the latest kernel i used a HJTAG. I got a detail info from the link http://www.andahammer.com/faq/ Thanks &Regards emebddedsms
