Hello;
I'm recently start training with ARM9-mini2440 board.
* after power on :
- on top of DNW window i get : [com4,115200bps][usb,ok]
-and I recives correctly on the DWN display the menu of
"FriendlyARM Bios for 2440" and in the board the green
led1 blinking
=>but as I try to send program to the ARM board " DNW ->usbPort ->transmit"
the download process never starts and the text appear in the DNW disply
" [ERROR, File open] "
I spend a lot of time, but I have not found the solution for this problem
thanks if you could help solve my distress.
haithem.
Download process never starts [ERROR : File open]
One topic is enough! What file do you want to transmit and where is the file stored on? On hard disk drive?
Maybe this problem http://www.friendlyarm.net/forum/topic/654
good day Now, I format the NAND flash from address 0x5000 to 0x40000 (I have 64 MB memory card), and the bios "vivi" remain installed. Finally, I try to send a "file.bin" from my hard disc, but this error appear. but, when the friendlyarm in the original state and everything is installed by the factory, I try to send the file "2440test_A70.bin" and still the same error appear. thank you
Do you use the DNW version from the download section? Here is also a small download guide: http://www.friendlyarm.net/dl.php?file=download.pdf http://www.friendlyarm.net/dl.php?file=linux_download.pdf
I try with different version of DNW, but the process of downloading it didn't start. always the same error "[ERROR: File Open]" Please help me, I am stuck since the last week
64M with 7.0" display? You can re-install the factory distro and everything works OK? 2440test_A70.bin (The default output is Innolux 7 inch LCD)
Yes, I have the vesion 64M with 7.0 "display of the chart mini2440. At first I have to format the NAND flash from address 0x5000 to the address 0x4000000, so I have not touched the distributed vivi (between 0x0 and 0x5000). then I send esseyer "2440test_A70.bin" and error "[ERROR, open file] appear. that's all my sad story. what do you think of my brobleme
Hello;
when power on my device and set any mode(nand\nor) mini arm display white
light. i connected jtag cable,usb cable,serial cable.
on top of DNW window i get : [com4,115200bps][usb: x]
how can i load supervivi in that device pls help me my email is
sk.safaruddin@gmail.com
[ERROR, File open] if this problem , please change the access limits: chmod 777 filename
