Hi, I have compiled kernel with ext3 support for my micro2440. Copied "Angstrom-mini2440-image-glibc-ipk-2009.X-test-20090405-mini2440.rootfs.ext 3.bz2" on sdcard in ext3 and kernel in vfat. Now with this I get following message while booting: Starting udevKernel panic - not syncing: Attempt to kill init: What could be the reason? TIA Kailas
Angstrom on SD card - Kernel Panic
Hi Buserror, can you please give me the .config file which you have used to build kernel for "Angstrom-mini2440-image-glibc-ipk-2009.X-test-20090405-mini2440.rootfs.ext 3.bz2". I tried building my own kernel for this file system but it is failing due to some udev related problems. uImage in your rootfs is working on my board but I want additional ACM support and my LCD is T35. You can send that .config file to me at kvshetye at yahoo dot com. Thanks and regards, Kailas Shetye
Look at this: http://www.friendlyarm.net/forum/topic/2785#lastpost
