Hi, I am facing a problem with microSD detection from uBoot and Linux. There are two issues for this problem. 1. Linux with working microSD goes for reboot. 2. Linux goes for continuous reboot due to kernel panic. The reason for continuous reboot of linux is as below. a. uBoot detects presence of microSD but reads Capacity as 0. (micro SD read CSD is not proper). b. Linux that is present in flash memory is booted. Linux fails to read microSD OCR, CSD etc. While loading rootfs from microSD, linux throws following error. VFS: Cannot open root device "msda1" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 1792 mtdblock1 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) Rebooting in 5 seconds.. Rootfs is present in the same microSD On giving power cycle to system, not facing any problems with the same microSD. Any clue on this issue is highly appreciated.
micro SD detection problem
I had almost the same problem long time ago. I found a solution here: http://billforums.station51.net/viewtopic.php?f=1&t=5 the rootwait in the bootargs was the solution. bootdelay is another option. take a look in the link. I hope I helped.
