Flash NOR with JTAG Problem
Coolkeum 2010-01-27 19:54:39 Link
Hi all,
I have tried to flash NOR with supervivi128M (for Samsung K9F1G08) in order
to use Windows CE 6.0.
However, after a complete download successfull, my mini2440 doesn't want to
boot : in S2 mode, DNW shows a random letter followed by "load Image of
Windows CE..." but nothing happens and in NOR mode, DNW only shows an
"i"...
In NOR mode also, with H-JTAG, the "detect target" works well but on
"Check" or "Program" button, H-Flasher says "Error : can't load to the
specify address" or after a programming try "Error : time out. This mean
something goes wrong." !
For information, I have used the H-JTAG distributed on the CD and
FriendlyARM2440.his / H-Flasher_mini2440.hfc files...
Anybody has an idea to help me in this critical situation?
Edje11 2010-01-27 20:07:11 Link
If you want to use CE6.0 you MUST use the supervivi and Nboot that's in the
win ce6.0 bsp.
http://www.friendlyarm.net/dl.php?file=wince6-bsp_20091203.zip
And here is a good tutorial how to use H-Jtag.
http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf
Have fun.
Coolkeum 2010-01-27 21:53:50 Link
Hi Edje11,
Thank for your reponse!
However, I can't flash anything else on my mini2440 board with H-JTAG
because it always shows "Error : can't load to the specify address"...
I have try the tutorial with the new supervivi-128M in the
wince6-bsp_20091203 and the result is still the same.
In another way, I have tried with sjf2440 utility which says "ID Check
Error" and shows me Manufacture ID equal to "7e" and Device ID equal to
"ea00" where as Friendly ARM user manual has a printscreen with "1" for
Manufacture ID and "2249" for Device ID in its user manual...
My board seems to be in a bad state :/
Coolkeum 2010-01-31 18:06:19 Link
Hi all,
I have tray again why my board today and I have another error now "Error :
can't halt target and make it enter DEBUG state".
On this error, my mini2440 board seems to "buzz" as a Windows click, you
know?
Anybody has an idea for me please?
Coolkeum 2010-01-31 18:10:54 Link
For information, I have also try to rewrite the manufacture / device ID,
with sjf2440 utility, in order to correspond to Friendly ARM documentation
printscreen. However, sjf2440 seems to write well but when I read the word
at address 0, nothing has changed...
If this can help you to help me also!
Gautam 2010-04-30 16:01:30 Link
Hi Coolkeum,
Please look at my answer to Marco's similar problem here:
http://www.friendlyarm.net/forum/topic/874
Hope it helps!
Good luck!
Gautam
prakash_veerappa 2010-08-04 11:21:43 Link
I am also facing the same problem as what coolkeum encountered.
Reply
Name
eMail (not visible)
Text
Please enter the number 3836
