There is couple of posts abot same problem but dont see any solution or coments about this problem! I am not able to figure this out for past 6 month Please any body help!!! Problem:Freshlu louded WinCE 6 image connects with Active sync without a glitch after a while (1-2 weeks of use ) when trying to connect using activesync 2440 displays connection present but PC active sync giving message "Cannot Verfy the version of ActiveSync on your device. A prgram such as Firewall may be blocking a port ActiveSync uses to connect to the device, or you may need to update to more reasent version of ActiveSync on PC" the computers I am heving this problem have no antivirus! firewall is turned OFF. ActiveSink was tested 4.1-4.5
ActiveSync failuer to connect
Actually this situation has been reported already: http://www.friendlyarm.net/forum/topic/2624 Sadly, it seems there is not solution for this.
Same goes here! While developing applications, we have to load new image every 1-2weeks due to ActiveSync problems :(
