Hi All! I just got my Tiny6410 board and I am having problems booting it from the SD Card. I followed the procedure written here: http://www.friendlyarm.net/forum/topic/2061 but the thing still does not boot. It just stays there, with the screen showing static artefacts. My SD Card is structured as follows: Root |-/images/Android |-/images/FriendlyARM.ini I have changed the "OS= CE6" line to "OS= Android" and have flicked the S2 switch to the SD-BOOT position. When I prepared the SD Card on my PC using the SD-Flasher tool, it returns immediately saying ------------------ Fusing... 6410 superboot Image 1 Total, 1 Succeeded, 0 Failed, 0 Skipped ------------------ Is there a way to verify that Superboot has been flashed properly? Should it rename the card or create a new partition? I am running windows XP and I have used 3 different sd-cards (1GB/2GB/8GB). Many thanks!
tiny6410 and booting from SD
OK, I got it. For some reason, I need to flash superboot AFTER I copy the image files and change FriendlyARM.ini.
