Hi I have my mini6410, it boots wince Ok, but I can't boot from SD. I flash supervivi to the SD card (8gB SDHC), SD-Flasher returns succesfully inmediatly , but I cannot see any file in the card (using Windows explorer). Can someone help me?. Thanks. Guillermo
mini6410 sd memory issue
To boot from SD I use SuperBoot Included in de DVD, images/superboot-20100624.bin flash this file with SD-Flasher Don't forget change de switch NAND to NOR.
No way to flash superboot with sd-flasher. Same problem. Can some one tell me what is the purpose of using sd-flasher? Isn't any other way to do the same thing? thankyou
Hi. SD-Flasher prepare the SD to boot from it. Superboot it's a boot loader. That you can't see files of Superboot or Supervivi isn't a error To boot from the SD, you need to do this steps: 1. Create a FAT Partition(FAT32) in the SD. 2. Flash Superboot in the FAT partition using SD-Flasher. 3. Copy the file FriendlyARM.ini to the SD 4 Copy the image system that you want to run into the SD. 5. Edit FriendlyARM.ini to configure wich system will be boot. For example if you want to run WindowsCE from the SD, create a directory call images into the SD, then copy the directory WindowsCE6(included in the DVD (images/WindowsCE6/) to the SD. Open the FriendlyARM.ini(SD) and change "Action=install" to "Action=run" and "OS= Linux" to "OS= WindowsCE6" then change the switch from NAND to NOR and reboot the board. The file FriendlyARM.ini must be on the root of the SD. Bye.
Hi, I have same problem with boot from SD card. I try many times but I can't success. My SD card is 2-GByte capacity.
Well. Solved it by replacing the card. The non-working was a TF card, and the guide says it may not work.
