I've got a Qt4.7 app that works just fine if I wait to manually run it until the mini2440 has fully booted: /myapp -qws and the app works just like it should. However if I add that line to the end of the /etc/init.d/rcS file (to run it automatically at startup), I get: /myapp: error while loading shared libraries: libts-0.0.so.0: cannot open shared object file: No such file or directory I've been searching for a while and although some people have had the missing library problem, none of them are due to running the app from the startup script. Any ideas? -Seth
Libts error only when starting app at startup
After another round of Googling I found this post: http://www.friendlyarm.net/forum/topic/465 which explains the solution. Thanks anyway! -Seth
Dear Seth, copy libts files and paste them in your folder having lib path, you might have set in env variables or add path to these files. Thanks
