Hi all, I would like to launch an application right afer booting (at the moment I need to login in and launch it manually). When launching the application after booting (before login) with script (using the last script in 'init.d') it fail : the app is launched but the touchscreen is not working (due to missing export as not logged in, or uncorrect rights ?) => how can I avoid login (or log automatically) ? best regards, David
how to launch an app. after booting automatically ?
Hi, ahoo, which embedded os do you use? for Linux, you can edit "/etc/init.d/rcS" file for WinCE, you can use "Autorun-Setting.exe" to set. regards mindee
I am using linux but as I described I tried in the rcS file but it fail since app launches but touchscreen then doesn't work. That's why I though of automatic login (since when logged in it works) thanks
Hi David, I also notice the same trouble as yours. When I want to automaticaly lunch an application after the boot, the following message appears : > error while loading shared libraries: libts-0.0.so.0: cannot open shared > object file: No such file or directory Did you finally find a solution for this issue ? Thanks
Hi Skip2816, Thanks for your helpfull reply. Actually yes, the libts-0.0.so.0 exists ... but in /usr/local/lib/ directoy. I copy the libts* files in /lib/ directory and now my application is correctly launched. I agree that this is not a good manner to proceed. I think my path is not correct ... how can I set it correctly ! Do you have suggestion ? In anycase thank you for putting me on the way !
reHi, If I well understood, the /etc/profile is launched after /etc/init.d/rcS. In my case, the PATH setting figures in /etc/profile and I try to lunched my application in /etc/init.d/rcS. It means that when I launch my application the PATH is not already patched. So, I think this is the reason why I had this trouble. I have to better understand the boot process ... Thanks for your help
see /bin/qtopia i just commented qpe and added my app there. this file sets up all necessary stuff. touchscreen and the environment. let me know if you run into any problem
You must write bash script witch exports all needed environment variables and then launches Your app. Then add it to rcS file with '&' for example: /home/myscript & Remember to write full path. Or the other option is to export all variables in QT application. It is important because if You have all variables in /etc/profile and application is triggered by rcS it won't work - rcS is read first then /etc/profile. good luck best regards Tom
