Hi All. I am trying to use a MicroSD of 8 GB, but when Uboot starts i got this error MMC: error found: 0001 If I use a MicroSD of 1GB all ok. So, how can I configure Uboot to boot a MicroSD of 8 GB? I suppose that I need to compile Uboot no? I have the Uboot source of Mini6010 board. Thanks :)
UBoot and MicroSD 8GB
u-boot source code is in DVD/linux/u-boot-mini6410-20101106.tar.gz but the u-boot dont support SDHC. Superboot support SDHC, but superboot is not open.
Thanks for answer. Superboot can boot ext3/ext4 file systems? or only boot from FAT file systems? I trying to boot Debian from the MicroSD on my Mini6410 but if I used a MicrosSD of 8GB don't work. I can run Debian but loading the Kernel from the NAND a then load the root file system from the MicroSD of 8GB. Thanks :)
I was tested again Superboot, but then only way to run the SO from the MicroSD was: * Delete all partitions. * Create 3 partitions *- 2GB FAT32(Superboot, Kernel and root file system) *- 512 SWAP *- 5GB EXT3(Home) * create the "images" directory in the FAT32 partition * Create a directory to save the Kernel and the system called "Debian" * Create a image of my Debian using the mkext3image * Put the Kernel and the system image into the Debian folder * Copy and edit the Friendlyarm.ini file and saved it in the images folder. Now my Mini6410 runs Debian entirely from the MicroSD, but my original idea was run Debian on ext(x) partition, and without using a file image of the system. Thanks.
Hi, Try Tekkaman ninja's uboot version 2010.03 if I remember. It handles SDHC cards. Have a look to this : http://www.friendlyarm.net/forum/topic/1922 Good luck
If I try to upload the file to the NAND, I got a message error "DNW download Data size is too big Download uboot failed". This file is to use in the NAND or in the SD? if I try to flash it in the SD with SD-Flasher I got a error too. Thanks.
