Hello I got mini240. How to program in linux Mini2440 related. Can you give me a source.
Mini2440 with linux
http://www.friendlyarm.net/forum/topic/26 http://www.friendlyarm.net/forum/topic/38 http://www.friendlyarm.net/forum/topic/113 There are also many tutorials and guides about embedded linux programming on the internet.
hello dear, me also same problem There are also many tutorials and guides about embedded linux programming on the internet. so replay me thanks reg Ramesh k
hello dear, me also same problem I got mini240. How to program in linux Mini2440 related. Can you give me a source. so replay me thanks reg Ramesh k
If you want to program the Mini2440 in linux using the existing bootloader, use this program I linked to. It is based off of the "qt2410_boot_usb" but I have fixed some noncritical bugs. http://www.sendspace.com/file/ua48xy
hi guys, To run a program in linux Mini2440 you have to compile the sources on a linux pc with a cross-compiler (http://www.friendlyarm.net/dl.php?file=arm-linux-gcc-4.3.2.tgz). Also read the mini2440 manual. All information about compiler, examples and system are described there... http://www.friendlyarm.net/micro2440/micro2440_manual_20090817.pdf its in chinese, but google translator will help you. best regards, gl eduardo
