Why 64 mb not showing for wince image running on mini2440 , whats the
change i have to make ram to 64 mb .
64 not showing in mini2440
Search the forum for RAM. http://www.friendlyarm.net/forum/topic/1425 http://www.friendlyarm.net/forum/topic/455 ...
Hi Rick , I have done according to that topic but its showing a colored screen after booting . i have given the same hex value as per that topic , Is it because i am giving correct 64 mb .
You can only get more RAM if you shrink your WinCE image. Because the whole image (NK.BIN) is loaded into RAM on startup.
Hi , But on board we are having 64 Mb memory . if i take system info in wince control panel its showing only 30MB so where the rest 30 Mb memory of RAM I have bought the board with 64 Mb . seen some changes to be made in config.bib file . but after making change on that file and compile then the its not booting Win CE .
Did you read the post right above yours? It reads "Because the whole image (NK.BIN) is loaded into RAM on startup.". Half your ram is GONE because the NK.BIN gets loaded there. It doesn't show as ram because NK.BIN can not be removed. If you did search then you would have seen that this question pops up about every two weeks. And it really does get annoying to answer it every time.
