I bought one mini2440 1Gb and one micro2440 256Mb. Both with only 64Mb Ram memory. I succesfully created and uploaded my BSP, size near 29Mbyte. When I run my Wince application, it's loaded in residual memory, about 30Mbyte. After few minutes memory free is only 10% and a few minutes later i receive out of memory exception. There is a way to use biggest Flash memory to expand RAM size (for BSP or for application memory)? Thanks in advance for and tips. Max
Ram and Flash memory - Too small?
hy.... I have same problem... some one have a clue about this? Why in Windows CE see only 29MB RAM not 64MB?
Look like a memory leak... You should check your code.... Zogzog. Paranoid Club meeting this Friday. Now ... just try to find out where!
how do i do so that windows ce doesn't run from RAM but from flash and this way i would have more RAM free? Thanks
Rob
WinCE runs from RAM, thats why you only have around 30 MB.
I always wonder what is the purpouse of having 128Mb or more in flash if
you can't load an imagen bigger than the size of the RAM.
If you are coding with QT you might be using static link and have size of applications more than you need. Change the configuration and make the size less by extracting unnecessary dll from your exe.
