Can anyone link me to the complete user manual that describes how to port WinCE onto the device? I noticed the user manual gets chopped off at page 30 :( and porting the OS is on page 109.
Porting Win CE
Its not really a port its all about Windows platform builder. You will see the BSP's and SDK's in the download area - Board Support Package and Software development kit (drived and built fom the BSP) Think you need to start reading up on windows ce 5 or 6 start at the top and work down - lots of downloading..... http://www.microsoft.com/windowsembedded/en-us/products/windowsce/gettin... then its about getting those BSP open with all that installed software and chosing components
Also very useful: http://code.google.com/p/friendlyarm/wiki/WinCE
Thanks for the reply adam. The manual makes it very clear how to install the OS but when I boot in NOR, the BIOS does not come up. My hyperterminal remains blank. I'm able to transfer files through serial on DNW though, does anyone else have this problem?
I had similar problem - when you programed the nand it would run ce straight away but failed to start after a reboot. I had an older version of supervivi - as the last option in supervivi it should say [i] 0945-2K or something very similar (dont have the gear to hand) - use the supervivi attached - as be ware the different LCD types i have 128mb 7" so its the A70 version
Alex: > The manual makes it very clear how to install the OS but when I boot in > NOR, the BIOS does not come up. My hyperterminal remains blank. I'm able > to transfer files through serial on DNW though, does anyone else have > this problem? Have you checked the serial cable (straight) and is the com port setting correct? http://www.friendlyarm.net/forum/topic/347
I've flashed it using the serial port and DNW onto the device but hyperterminal is still blank. If i connect with DNW, it says in Hyper Terminal that the port is being used.
Are you using the menu in DNW "Serial Port->Connect"? - i dont really know what is the question. I would usually forget about hyperterminal - just connect the min2440 using the "Serial Port->Connect" AND press return to ensure the menu comes up. Also not if the usb link is "OK2 in the title menu. if the bios is shot the JTAG can be used to bring it back up - just follow the friendly arm guide for H-JTAG http://www.friendlyarm.net/dl.php?file=download.pdf
Hmm, I thought I was doing it correctly but I guess not. I connected the serial cable and then went to device manager to check which port (COM 4). I then set the buad rate to 115200. When I press connect it shows [COM4, 115200bps] but when I press return it doesn't show the bootmenu.
http://www.youtube.com/watch?v=9UG5vhOMl0g I am testing my own BSP with SPI,GPIO,IIC,French/German/English Locales on, with 7" screen plus silverlight. I think we are in same boat perhaps - I am coming from electronics/automation background and am using this as a get-up-to-date exercise!
Dear adam watson, Could you sen me your BSP for english ? Or could you tell me how to install wince in english, I've manage to install Windows CE 6 in my mini2440 (128, T35), but all menus are in chinese. Waiting for your answer, Birlan
