Hi all, I am working with a mini2440 based robot. I have interfaced 4 analog sensors with my 4 ADC channels. These were working fine till about a few days back. But now the adc channels are giving a problem. The read value always seems to be -1. When i try "cat /dev/adc" or "cat /dev/adc1", etc i keep seeing a value -1. What does this mean? I checked mt sensors and they are fine. Does it mean that the ADC port has burnt up? Please help Thanks in advance Chinmay
ADC reading is -1
Have the same problem but my ADC started to give a problem after some time of working. Suddenly it started to give -1 and touchscreen wasn't responding. When I disconnected my sensor, and killed program that was reading from that sensor - touchscreen started to work. Maybe any ideas? thanks in advance best regards Tom
To make the analogue channels working in combination with the touch a state machine is required, because there is only one real ADC for all input channels. Maybe the driver is broken.
Using a working driver. Sorry, there is no information about the kernel you are using, no links to sources, no configuration you are using to build the kernel and to configure runtime. How should I help you? In my kernel I can use the touch and the other ADC channels. You can find it here: http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
Okay, why not starting with a more current kernel (say 2.6.38) and adding a few missing patches to make the ADC work? Are you experienced with kernel patching? If yes, try googeling around for Marek's patches. Or use the patch stack from my board support package mentioned in http://www.friendlyarm.net/forum/topic/2779. When you extract the repository, you will find the patch stack in "configs/platform-friendlyarm-mini2440/patches/linux-2.6.38"
