I am stuck on the last process, that of uploading the images via tftp to the mini2440. I am quite sure that the tftp server is running correctly on my Ubuntu 10.04LTS host. However, on running <update -t barebox -d nand> I get: tftp failed: No such file or directory I can ping the server from the mini2440, but I can't ping the mini2440 from the server end. Is this normal? Another issue that might surface later, when I can upload files to the mini2440 is . . . on the top of page 22 it says to: $ cp platform-mini2440/images/barebox-image /tftpboot/barebox-mini2440 As the barebox image was already loaded via USB (page 20) I wonder if this should really be: $ cp platform-mini2440/images/barebox-default-environment /tftpboot/barebox-mini2440 If not, what is this file for? Dave
OSELAS.BSP mini2440
tftp failure: There are some tftp servers around expecting the full path from the target. I'm using dnsmasq acting as tftp server. Can you see in the logfiles at the server why it fails or what file your target requests? The bootloader does only support polling. So, ping-ing your target won't wake it, to send an answer. Loading barebox via USB only loads it into the RAM. The next step loading it again via net is to make it persistent. "barebox-default-environment" is for convenience only. It contains the evnironment, barebox should use, and can be stored directly into the flash. But when you set up your target the very first time, it is not required (it contains the same info as the default environment). The really "barebox-image" is needed to be downloaded via net in this step. Hope it helps.
Juergen, Thank you for the quick response. The issue with <tftpd-hpa> on my platform was traced when doing: cat /etc/default/tftpd-hpa It was expecting to find the tftpboot files in /var/lib so I changed TFTP_DIRECTORY="/tftpboot" and the files uploaded. That was after a long search! Also, on waking this morning I realised that uploading barebox into nand was necessary, but thanks for correcting my doubt. Now, for the next problem! When I set the unit back to NAND and re-power all I get is a white screen immediately and no communication takes place on minicom. The barebox image is 149788 the root.jffs2 image is 4771060 the linuximage is 1600848 I reflashed the images and the same thing happens. Appreciate your suggestions. Would you prefer this dialogue takes place on your mailing list? Regards, Dave
Did you check your NAND configuration (64 MiB versus non 64 MiB) and build the coresponding config? > Would you prefer this dialogue takes place on your mailing list? Yes, on the mailing list would be easier, as I read this forum only once a day. jbe
Continued the discussion at: http://permalink.gmane.org/gmane.comp.embedded.ptxdist.oselas.community/1
Reporting back: A useful test has been suggested just after loading barebox into RAM. mini2440:/ nand_boot_test 0x31000000 0x40000 mini2440:/ go 0x31000000 Hit any key to stop autoboot: If you got this far you have probably got a good barebox image in RAM. I re-installed <tftpd> on my Ubuntu 10.04LTS host, which MAY have had something to do with things now working. I'll never know! The support on this issue has been exceptional. Dave
Hi , Is it possible to load the kernel and the root fs image built by OSELAS.BSP via u-boot instead of barebox? Currently i'am using 'bootargs console=ttySAC0,115200 init=/linuxrc noinitrd root=/dev/nfs rw,tcp nfsroot=192.168.1.3:/fs/qt463 ip=dhcp' to boot linux My question is what parameters I need to pass to bootargs so the kernel boots and mounts the root filesystem. thanks --amit
Starting at section 2.2.4 in OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf: <ptxdist setup> from memory just does some initial setup, not sure if you can change the bootloaders from here. Then try <ptxdist menuconfig> and tick u-boot. Here is my NFS commandline for barebox, maybe it gives a few clues: nfsroot=192.168.1.7:/home/davef/Pengutronix/OSELAS.BSP-Pengutronix-Mini2440-2011 .05.0/platform-mini2440/root,v3,tcp noinitrd ip=192.168.1.147::192.168.1.254:255.255.255.0::: mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) arch_number: 1999 Currently, working with Juergen trying to get this to work. http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community Good luck.
fatbrain, no problem. My BSP creates the kernel and the rootfs, and they do not depend on any bootloader. So, you can also use u-boot to load and run the components created by this BSP. You should adapt your kernel command line. Remove the "init=/linuxrc", as the kernel tries to run "/bin/init" and it will work with the root fs from the BSP. And adapt the nfsroot as Dave already stated. Nothing magically.
