Length of file is too big
ARCANGEL 2010-06-24 21:06:52 Link
Hola
after formating the NAND flash. with the DNW
im trying to upload supervivi-64m  to my mini2440, that is a 64
and get this message
" Length of file is too big : 256416 > 163840
Failed downloading file "
instead i uploaded the " supervivi_mini2440 " but is not booting
how can i upload the -64m ?
thanks
david 2010-06-24 21:14:36 Link
i think that you may be are trying to install a wrong version of supervivi
look on dowloads there you can find the packages you are going to need
ARCANGEL 2010-06-24 21:35:57 Link
hola
i downloaded this file  " supervivi_20090721.zip "
the supervivi-64M is     251 kb
try to upload it after the format (x)  and get the same message
my board is 64m
tom 2010-06-24 22:26:57 Link
You need to update your supervivi in NOR memory.
ARCANGEL 2010-06-24 23:41:45 Link
updating NOR is where i get the message, is there a way to increase the
partition ?
tom 2010-06-25 09:46:20 Link
I mean updating the NOR with H-JTAG:
http://www.friendlyarm.net/dl.php?file=download.pdf
majid 2010-11-15 21:39:14 Link
I also received this error om mini2440-128M:
even programming the SST39VF1601 via JTAG was not useful !
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[b] Boot the system
[s] Set the boot parameters
[q] Goto shell of vivi
[i] Version: 1026-2K
Enter your selection: x
Found block size = 0x00020000
Erasing...    ... done
Writing...    ... done
Written 49152 bytes
Saved vivi private data
Enter your selection: v
Now, Downloading [ADDRESS:30000000h,TOTAL:249258]
RECEIVED FILE SIZE:  249258 (243KB/S, 1S)
Downloaded file at 0x30000000, size = 249248 bytes
Found block size = 0x00040000
Erasing...    ... done
Writing...    ... done
Written 249248 bytes
Enter your selection: k
Length of file is too big : 2516916 > 2097152
majid 2010-11-15 21:42:10 Link
by the way, file is zImage_T35 [2.39 MB (2,516,916 bytes)] from download
page
majid 2010-11-15 21:44:11 Link
it is wright. SST39VF1601 has only 2 MByte !
majid 2010-11-15 21:49:14 Link
but now (k section) we program 128MB NAND !
is it an uploader bug?
davef 2010-11-15 21:51:49 Link
But, there is more than one of them.
Search around for <kernel partition size>  There have been some postings
about similar issues.
davef 2010-11-15 21:55:33 Link
< But, there is more than one of them.
That probably wasn't the right answer!
I mean there is at least 64M of space in flash, so I think you need to
change partition size.
majid 2010-11-15 22:01:15 Link
what is the tool?
davef 2010-11-15 22:14:33 Link
1st hit on <change kernel partition>
http://www.friendlyarm.net/forum/topic/541
Reply
Name
eMail (not visible)
Text
Please enter the number 9832
