Hi , When i was trying to do some stuff, somehow bootloader in the NOR flash got erased . So when i start in nor flash mode. it is not getting booted and so iam not able download anything. So please i request u to send the vivi boatloader image (NOR FLASH) which is shipped with 2440. Thank you Naveen
I need image of bootloader of NOR FLash
Hey! Few seconds ago I tested latest bootloader you can find in download section of this page. It worked just fine. Here are some links, that might help you: Supervivi images (for 64M and 128M flash size) http://www.friendlyarm.net/dl.php?file=supervivi_20091110.zip Instructions you might need. http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf Other useful stuff: http://www.friendlyarm.net/downloads Hope this helps, Beer
Hi Beer , Thanks for information. I was able to solve the problem. Actually problem was , serial cable was put reverse i .e connector which should go to the Board was connected to PC . There is a confusion in the cable because both sides are female. Naveen
The "confusion" must be a wiring fault. Buy another cable, you don't want problems like this . . . there will be plenty of other problems to sort out!
dear sir, can you pls tell me what screen will appear when botting is done on NAND after linux installation in NOR. i.e after all installation we shut off the board switch to nand and then switch on the board. so what image it shows? does it remain blank i.e white? thank you
