Hi. I use Suse 10.0. I have a problem while I build arm-qtopia-2.2.0_20090429.tgz. after start ./build i received error: .... Creating pngscale...make[1]: Entering directory `/opt/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/util/pngscale' ..make[1]: *** [../../bin/pngscale] Error 1 make[1]: Leaving directory `/opt/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/util/pngscale' Failed to make pngscale *********************************************************************** * * ERROR: Building Qtopia has failed. * * Please search the make output for any error messages. * * Hint: If the configuration has changed since the last successfull * build consider using make clean to ensure that all binaries * are rebuilt using the new configuration. * * For more information about the build process please use a browser * and go to the getting started section in: * /opt/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/doc/html/index.html * *********************************************************************** I use arm-linux-gcc-4.3.2 What can I do ?
Qt 2.2.0 build problem
Hi. I have new facts in my case: I turned on the verbose mode, and I received new message: /usr/lib/gcc/i586-suse-linux/4.0.2/../../../../i586-suse-linux/bin/ld: cannot find -luuid What it means ? Where can I find uuid library for my system (SUSE 10.0) ? Regards
Hi, again me :) I found the reason of my problems: my Suse was not complete. When I have installed all needed items, everything is going ok. Regard, and thanks for your patience :)
Hi, I am using Debian lenny, and have solved this problem. $ sudo apt-get install libuuid1 $ sudo ln -sv /lib/libuuid.so.1.2 /lib/libuuid.so
Hi, I found, I also habe failed to build qt 2.2.0! Because by making error.log I found building is failed in several times. Now I will analyse this log file to prevent failure later.
Hi, I also have the problem of pngscale not found. I am using Fedora12 to compile. In the thread it is mentioned that Suse is not complete. My I know what is needed in Fedora to compile ? RKota +++++++++++++ Creating pngscale...make[1]: Entering directory `/opt/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/util/pngscale' ..make[1]: *** [../../bin/pngscale] Error 1 ++++++++++++++
