Hi, I am new to Win CE. I do want to develope my own supervivi bootloader for mini2440 board. How to do? Which compilers should I use for the same? I sit possible in VC2005? Please help me.
Supervivi-128M
"I sit possible in VC2005?" this is typing mistake.. Is it possible to compile and generate "Supervivi-128M" bootloader by using VC2005?
Hi We have purchased some micro2440 boards. I want to shift the console from ttyASC0 to ttyASC1 permanently. I need the source code of supervivi bootloader.. where can i get the source code....?
Hi Raju, As per my knowledge, ttySAC0/1 are serial port device name under Linux and not for Supervivi which runs before the Linux kernel boots up. If you want to change the console for the Linux kernel, you can make changes to the Linux kernel command line from the Supervivi command prompt. You don't need to change the Supervivi code for that. Gautam
to change the console device, it is the KERNEL configuration you need to play with make menuconfig Boot options ----> Default kernel command stiring. it is currently: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0 or you can go into "zImage" with a hex editor to the image and change 1 byte. but before you start playing about , may i recommend you become familiar with HOW linux boots Because if you break something, you will have a hell of a job understanding how to fix it.
