Hello All, I'm considering the mini2440 for a project that, among other things, needs some RS232 ports. However, none of the serial ports seems to include RS232 control signals, e.g. RTS, CTS etc. (Not even the port that has a DB9 connector - at least not documented in the available schematics in the downloads section). Are these control signals available somewhere and are they supported by the WinCE drivers? If not, how do one go about adding these pins to the available ports and ensure WinCE driver support? Also, one or more PCMCIA and CF ports would be nice. Any ideas about how to add them to e.g. the system bus and support them in WinCE? (Perhaps PC104 modules with WinCE drivers or something like that?) Thanks in advance. Best regards, gch
RS232 control signals etc
i am using embedsky 2440 not mini2440 they look almost same and i have cts and rts signals on com port 1 and if i want to use com port 2 then com port 3 becomes rts and cts yes there is slight change is driver of serial port you should see in serial.c or files that comes with your mini2440
> However, none of the serial ports seems to include RS232 control signals, > e.g. RTS, CTS etc. (Not even the port that has a DB9 connector - at least > not documented in the available schematics in the downloads section). The DB9 connector (COM0) on the Mini2440 has also connected RTS and CTS. Have a look in the schematics on page 6: Serial Interface http://www.friendlyarm.net/mini2440/mini2440_schematic.pdf Regards, Andreas
Thanks for the answers. Much appreciated. Guess I didn't read that schematic too carefully - sorry about that. Ok, that gives me one RS232 port with control signals and that might be sufficient. I did study the schematics further, and noticed that the rx and tx pins for UART2 seems to double as rts and cts for UART1 (the pins called nRTS1/TXD2 and nCTS1/RXD2). That might indicate that the UARTs can be configured as two ports, both with control signals, rather than one port with control signals and two without. Section 11, UART, in the S3C2440 datasheet doesn't mention anything specific about this, except that the modem control lines are available for UART0 and 1, nothing about how to configure UART2 as control signals for UART1. (Or rather, i haven't been able to spot it. It's likely in there somewhere). I've also had a look at the source files in the BSP, but i find it difficult to locate the place where the mode for the UARTs are set. It would be nice to be able to select between those two configurations. Any ideas? I also noticed that the BSP includes driver stuff for pc cards, i.e. pcmcia. I wonder if it's possible to connect a PCMCIA socket to the mini2440 in such a way that it'll be supported by this driver? Thanks again. Brgds, gch
