Hello I try to create first application for my WIN CE 2440. I try to generate SDK in platform builder (follow http://www.domodom.fr/spip/Ma-premiere-application-sous.html). When i try open "mini2440.sln" file from C:\WINCE600\OSDesigns\Mini2440 , i have information : "platform Biulder determine that the OS desig you are opening conatins Catalog items that are not found in the current Calatog. The following Catalog items have been deprecated. To remove the listed Catalog items from your OS design before Platform Builder opens it, make sure that the catalog items you want to remove are selected and choose OK. To continue opening your OS design without removing any of listed catalog items, choose canel. item:MS:sysgen_sdbus2 item:MS:sysgen_dotnetv35 item:MS:sysgen_sqlcompact _____________________________-- Well, what is the problem ?
SDK creation problem
Did you install Windows Embedded CE and generate your own nk.bin ? If you just want to write an application without doing your own nk.bin, you don't have to generate your own sdk but use the one delivered with your nk.bin. domdom
I have the same problem. The nk.bin that I have is in Chinese. I need to generate NK_N35.bin in English.
