Hello, It seem's that i succeed in compiling QT 4.6.2 but what to do now ? How can i make an image that i can download to the mini2440 ( like Qtopia 2.2 with "root_qtopiaxxx.img" ) ? Thank you for your help !
QT 4.6.2 installation
Hi Fred, I'm from France also, and I'm in the same step as you. The questions I have : -Is Qt a kind of software, library or layer, needed on the target to allow applications to work ? - Or is it just an IDE which runs on the host and produces apps for the target which runs stand alone ? In fact, I would like to be able to launch this demo and create some apps like this one : http://www.youtube.com/watch?v=xiVNMtmsBoo I don't want to use any MMC distro, like you, I would like to use it in NAND memory with 2.6.32 kernel in nand memory. Can anybody explain how all those stuff works? Regards
Hi Screwface, I didn't work on Qt 4.6 these last days but i will restart maybe this week end. for me, Qt is only a lib that run on linux and which integrate GUI and lib for compiling application that run with this GUI. I try to follow the italian tutorial, i manage to compile the libs and to export them into the board ( /usr/local/Qt/lib ), but after, i need to setup linux to run one of this lib. This step fails because i'm not able to find where the Qt 4.6 libs is started... Do you have more ? Fred
Hi Fred, I think you're more advanced than me : how did you export the libs on the board ? When I compile on the host, I get all the libs compiled. But I do not know how to deploy the compiled libs on the target. I thought copying everything on a USB stick, but I'm not sure it is the good way. I'm looking for some books on Qt, I've found 2 of them, I'll give you the links if they are interesting. Thanks
Hi guys,
The hierarchy of the device softwares is like this...
_________________________________________
|Qtopia |
|Qt Embedded |
|Frame Buffer| |
|Embedded Linux is the OS for the device.|
|________________________________________|
The embedded linux provides the OS functionalities to the device. Qtopia is
the graphical environment to view the graphical applications made in Qt.
Qt is an intutive extended C++ GUI library. Just like in C++ you include
header files and write your own code, similarly using Qt libraries you
write a Qt code and creat a Qt app. The internal calls and subroutines to
run this app, are provided by Qtopia.
I hope this helps.
I write a sample code.
//This is the header file sample.h
#ifdef SAMPLE_H
#define SAMPLE_H
#include "sampleform.h"//When you create a UI file in Qt designer, you
// store it as file with .ui extension. The UIC internally and
//automatically converts the .ui file into .h i.e. header file.
// Thus the SampleForm is the name of the class of the form you create
class Sample : public SampleForm
public:
Sample(QWidget *parent=0, const char *name=0, WFlags
fl=0);//constructor definition
virtual ~Sample();//destructor
public slots:
virtual void printMsg();
#endif //SAMPLE_H
//THis is the implementation file sample.cpp
#include "sample.h"
#include <qlabel.h>//an API of Qt which has a label class.
#include <qpushbutton.h>//an API of Qt which has a button class
Sample::Sample(QWidget *parent, const char *name, WFlags fl):
SampleForm(parent,name,fl)
connect(PushButton,SIGNAL(clicked()),this,SLOT(printMsg()));
//PushButton is already drawn on the UI file and name is PushButton
Sample::~Sample()
void Smaple::printMsg()
TextLabel->setText("Hello Qt");//the label is already drawn on th UI
//file and the name is given as TextLabel
//main file main.cpp
#include "sample.h"
#include <qtopia/qpeapplication.h>
QTOPIA_ADD_APPLICATION("sample",Sample)//predefined macro
QTOPIA_MAIN//predfined macro of the main function
//project file sample.pro
CONFIG += qtopiaapp
CONFIG -= buildQuicklaunch
DESTDIR = $(QPEDIR)/bin
HEADERS = sample.h
SOURCES = sample.cpp
SOURCES+=main.cpp
INTERFACES = sampleform.ui
TARGET = sample
build this using the build script, similar to the one in hello example
To understand Qt you must be familiar with C++. I hope this helps.
Dear Yayati, Thanks for the explanation. But as far as I know, Qtopia is not developped anymore. So what I have understood is Qtopia is just a graphical desktop, written in Qt and relying on Qt libraries. So it is possible to write apps in Qt with Qt Designer for example which runs directly, at the same level as Qtopia (such as the Qt widget demo for example). I have understood that the libraries should be built on the host and then deployed on the target. This is the point where I'm stuck. I don't know how to do this. I compiled the libraries sucessfully for Arm, now I get everything compiled for Arm in my /usr/local/Qt folder on the host. But then, how to proceed with the next step?
Hi Screwface, Don't rush to arm device directly. Just make a simple application. As i have given one simple application. I go to terminal and i say #cd /opt/FriendlyARM/mini2440/x86-qtopia/Sample/ Now i say #./build and if the code has no errors it will compile fine. Then just run the run-sample script file. #./run-sample and now the code will run in frame buffer. If your code works fine on x86 then just copy your project code folder and paste it into /opt/FriendlyARM/mini2440/arm-qtopia Now just remove the build script which was for x86, and replace it with the build script for arm. and build your code again with the build script for arm. If you have installed the basic setup which comes with the friendlyARM DVD, then just read the hello example code for x86 and for arm. If you have created the code and compiled fine then just copy the bin and port it to the device. Have you installed the vivi, bootloader, root_qtopia etc..etc..images to the device??Is your device ready with in built applications running on it?
In fact I wanted to launch the demos to see if everything works fine before creating my own programs. My device contains the original FriendlyArm image (the lastest one) with Qtopia 2.2.0. The main idea was to use a basic linux image without Qtopia and add Qt 4.6.2. So for the moment, my main question is, how to run the Qt 4.6.2 widget demo. Once this will work, I'll be sure my board will be operationnal, I'll start to implement so small programs such as hello on the host, running it un QVB as per your advice and if this is OK, deploy it on the target
Well in that case, i need to know about the Qt 4.6.2 demo. Is it a binary executable or is a source code?
I don't know this detail. Here are some links http://www.youtube.com/watch#!v=xiVNMtmsBoo&feature=related http://www.youtube.com/watch?v=SyUyYHSbViU
Hi Screwface, I watched the video. If you have got the demo application's binary executable. then using hyperterminal, copy the executable to the target board's Qtopia/bin. And create a desktop entry of the executable and copy it to the device. If the name of executable is demo then name the desktop entry file as demo.desktop. When you restart the board, the icon to your demo will appear on the desktop or start up screen of your friendly ARM device. Click on it and the application will start.
Hi Yayati Thank you for this explanation, but I'm missing something. I don't understand what's the use of the Qt package we download from Trolltech qt-everywhere-opensource-src-4.6.2.tar.gz. What is it used to? I compile it for ARM architecture on the host, but once this step is done, what am I supposed to do? I'm a bit confused with that. Thanks
The package you download from qt.trolltech.com is a library to develop applications. Where as the videos which you told me, are of the application which they have already made using Qt 4.6.2 libarary. Just like in C, you write a code in editor and then compile the code. Once the code is compiled, the executable of the application you wrote, is ready. Thus to prepare that executable you need lbraries. For example in C, you have libraries like stdio.h,conio.h,dir.h,process.h,stdlib.h...etc..etc.. And you use these libraries to make your own application. Similarly to prepare GUI applications for embedded systems, Qt provides Qt libraries. Those libraries contain API to develop applications. Don't misunderstand between the source libraries, that you downloaded, and a application binary,which you have to write your code using those liraries. For example, Stdio.h is a library header file and a simple application like a game of Tic Tac Toe,is what you make using those libraries.
Hi Screwface, While i am also trying to compile Qt 4.6.2 for arm platform. I am struck on this point after i enter the command which you have given. the command is correct and it starts creating qmake. But it gives this error The tslib functionality test failed! You might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in /opt/FriendlyARM/mini2440/qt-everywhere-opensource-src-4.6.2/mkspecs/qws/linux- arm-g++. [root@localhost qt-everywhere-opensource-src-4.6.2]# [root@localhost qt-everywhere-opensource-src-4.6.2]# What should i do? Which Linux distribution are you using??
Ok, so the Qt package downloaded from qt.trolltech.com stays on the host and there is nothing to put on the target. The only thing needed to deploy on the target is the application written and compiled on the host. - But why do we need to compile the libraries on the host? Is it because of the application it contains (Qt designer and so on) ? - One last thing I'm not sure to have completely understood. If I take a linux image, without GUI, only linux kernel and things needed for it to run, and if I run the application written in Qt, should it work? Won't it miss some liraries or something specific to Qt on the target?
First of all, you need to understand why we have host and target. Just like Intel has its processor architecture, ARM also has its own architecture. As these two architectures are different so the opcode of the instructions which these processors process, vary. ARM provides architectures only for embedded systems upto my knowledge. Thus you must be having the host computer with x86 processor. The libraries have some dependencies with the processor architecture. Thus the libraries which are compiled for x86 architecture produce application for x86 machines. While the libraries compiled for ARM architecture, produce application for ARM machines. Just because you cannot develop applications directly on target device. This zig-zag way of first developing on host and then recompiling for target and then deploying it on target machine, is what you have to do. But tell me the linux distribution which you are using.
I agree with your explanation, I had this in mind. My question was more : no matter the architecture, a stdio.h library will be the same for x86 or ARM, it does not need to be compiled. So I wanted to know why should we compile Qt library. That's why I mentionned Qt designer which is an executable and needs to be compiled. I'm developping on Fedora 12
The library files, which we see, is in C language. C can be considered as high level language. While the compiler compiles the code, it creates .obj files and linker creates a .exe file(in windows) by linking the .onj files into one executable. This executable is processor dependent. The library in itself is just a code in some language. Have you heard of terms "Little endian" or "big endian". Even if you know, i'll brief you. In computing, endianness is the ordering of individually addressable sub-units (words, bytes, or even bits) within a longer data word stored in external memory. The most typical cases are the ordering of bytes within a 16-, 32-, or 64-bit word, where endianness is often simply referred to as byte order. The usual contrast is between most versus least significant byte first, called big-endian and little-endian respectively. Thus if x86 architecture has big endianness then the executable will consider writing from MSB(Most Significant Bit). While any other architecture which doesn't have big endiannes will start reading the code from some other bit or order. Thus some correct and meaning full code in big endianness will be useless and meaning less in other endianness. For example "My name is Yayati." This sentence is meaningfull if read from left to right and meaningless if read from right to left. Thus different processor architectures have many properties different while reading,analyzing and processing the code. This is where cross compiling makes the difference. So the library files must be compiled for x86 and ARM, both differently.
Ok, I know that. But if I understand in the right way, what you call library in Qt case is a kind of compiled executable, nothing to see with *.h files in C? It can be a kind of graphical kernel?
Ok, you do one thing. U just compile downloaded qt library for x86 platform. And prepare a small test application. Many of your doubts will fade away. Qt is internally C++ code itself. Those libraries are made of C++ lang itself. Like JAVA is based on C internally...similarly Qt is made of C++. I think you are just judging the thing. Don't complicate it...its very simple brother!!
Hi everyone.
I have tried to build QTopia 4.6.2(Ubuntu 10.04 LTS) and I have next
problems:
1. I try to build tslib and it failed:
./autogen.sh, OK!
./configure --build=i386-linux --host=arm-linux --target=arm-linux
--disable-inoutapi --prefix=${TSLIBOUTPUT}
=> checking command to parse link -dump -symbols output from gcc object...
failed
and
configure: WARNING: unrecognized options: --disable-inoutapi
And if I try to run make(after comment out malloc rpl malloc in config.h)
it given to next errors:
In function ‘open’,
inlined from ‘main’ at ts_calibrate.c:227:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’
declared with attribute error: open with O_CREAT in second argument needs 3
arguments
In function ‘open’,
inlined from ‘main’ at ts_calibrate.c:229:
arguments
What I can try to do?
Salut les gars ! Alors juste j'en profite pour vous dire qu'il y a une communauté en France qui s'installe autour de la mini2440. Rdv sur le forum de pobot [url]http://forum.pobot.org/topic81.html[/url] si vous préférez posez vos question en Français.... voila
j'ai oublié un truc super important : concernant vos question sur Qt je peux répondre en partie, m'y intéressant depuis des années sur PC. D'autre part, je vous conseille le trés bon tutorial de Paolo qui est en Italien sur Qt Italia mais aussi en Anglais sur son blog. Rdv sur mon blog [url]dlewin.free.fr/dablog[/url] (ou le forum de Pobot) pour en parler, voire traduire pour ceux que ça intéresse (Italien et Anglais)
Helo, I've had the same problem witch TSLIB. With this qmake.conf I've solved this problem and now I can compile applications with QtCreator 4.6.2 (ARM and x86). I hope this helps: # # qmake configuration for building with arm-linux-g++ # include(../../common/g++.conf) include(../../common/linux.conf) include(../../common/qws.conf) QMAKE_INCDIR = QMAKE_LIBDIR = QMAKE_INCDIR_X11 = QMAKE_LIBDIR_X11 = QMAKE_INCDIR_QT = $(QTDIR)/include QMAKE_LIBDIR_QT = $(QTDIR)/lib QMAKE_INCDIR_OPENGL = /usr/X11R6/include QMAKE_LIBDIR_OPENGL = /usr/X11R6/lib QMAKE_INCDIR_QTOPIA = $(QPEDIR)/include QMAKE_LIBDIR_QTOPIA = $(QPEDIR)/lib # modifications to g++.conf QMAKE_CC = arm-linux-gcc QMAKE_CXX = arm-linux-g++ QMAKE_LINK = arm-linux-g++ QMAKE_LINK_SHLIB = arm-linux-g++ # modifications to linux.conf QMAKE_AR = arm-linux-ar cqs QMAKE_OBJCOPY = arm-linux-objcopy QMAKE_STRIP = arm-linux-strip load(qt_config)
Hi all. I meet the same problem of "pera" compiling tslib on ubuntu 10.04. any help? Thank you ilpaso
Hi! I've got problem with building QT. The tslib functionality test failed! You might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in /opt/FriendlyARM/mini2440/qt-everywhere-opensource-src-4.6.2/mkspecs/qws/linux- arm-g++. Got built TSLIB in other folder. What's now? thanks best regards tomasz
Hi Tom, Try this tuto http://www.qtforum.org/article/27787/tuto-how-to-install-qt-embedded-lin... this error is because tslib is not installed properly on your host machine.
Hi Yayati Ekbote I read your description about porting the QT on a Linux embedded board and I found it very informative but I want to ask a little thing. actually I want to know that I am trying to port QT-embedded to my board and I am using the hierarchy of QT-embedded as follows: |||||||||||||||||||||||| | | | QT application | | | |||||||||||||||||||||||| | ||||||||| | QT Embedded Library | | | |||||||||||||||||||||||||||||||| | | | Linux kernel | | | ||||||||||||||||||||||||||||||||| I want to Know that am I write and if there is missing something , Please describe me . Thank you
