Hi all! I accidentally have switched between NOR-NAND while the board was enabled! Do anybody know what could go wrong with this? Is it possible to loose same data or be unable to boot?
NOR Powered on!!!
Hi Xristos ! i tried it once and nothing happened to the board, it remained totally normal. Regards.
Thank you mustapha I was not so carefull so I did it more than once. I had a software problem and I wanted to be sure it is not something more!
