Hello all,
I have mini2440, which i am using for studying.It's have 250M nand
flash. I want to compile the kernel(linux-2.6.29) and file system(yaffs2)
by arm-linux-3.4.1, then install it on mini2440. But it failed.Someone tell
me that arm-linux-3.4.1 don't support EABI and can't compile linux-2.6.29.
Is that true? And i found these problems
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2097-05-05 23:54:33 UTC
(401863
6473)
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
yaffs: auto selecting yaffs2
uncorrectable error : <3>uncorrectable error : <3>uncorrectable error :
<3>uncor
rectable error : <4>block 723 is bad
block 1965 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:3.
Freeing init memory: 128K
Kernel panic - not syncing: Attempted to kill init!
Help me please!!
Thanks.
about the arm-linux-gcc 3.4.1
hei, but i have a software that must used in the environment without EABI and used the arm-linux-gcc-3.4.1 to compile the kernel.
