Is anyone know how to add Arial font to the mini2440? Thanks!
Add fonts to FriendlyARM
Nobody knows how to add a font to QT running on the mini2440! It's hard to believe. Please respond if you know how....
adding any fonts to qt is a hard way. I spent much time without success. There are two ways: 1. Add a (fixed size) qpf-font. Therefor you must compile a tool makeqpf. After many many trys I gave up. 2. Recompiling qt/qtopia whith support for freetype. It is implicid disabled by any dependency, setting the parameters for configure does not work. I gave up. Hope you have more luck. skip
skip, thanks for your reponse. I also have not been able to get makeqpf to compile properly. If anyone has had success, please let us know....
Hello, I just have succeeded in adding true type font. there are two things to do 1. upload ttf file to /opt/Qtopia/lib/fonts directory 2. add line in file /opt/Qtopia/lib/fonts/fontdir as described here: http://doc.qt.nokia.com/qtopia2.2/html/fonts-qws.html For example I did: hebar hen.ttf FT n 50 0 Now my mini prints in cyrillic :-)
