Hi, I'm trying to use the first uart at ttl levels. I have connected an GPS receiver to the RX and TX pin of the serial port. My code works fine on any of the other two serial ports but on the first one, I don't get any data. I've already disabled the console on this serial port and I can read and write data when connecting with my pc through the max3232 chip using hyperterminal and the comport testprogram at the mini2440. Do I have to disable the max3232 chip somehow in order to use the serial port at ttl level? many thanks in advance mathez
Problems with /dev/ttySAC0 or max3232?
I think the max3232 has to be disabled in order to use RX and TX from CON1. But when I look in the schematics, there seems to be no possibilty for this. Maybe disassembling?
Did you connected your gps to the D-9 connector or the white plastic connector? On the white connector there's com1 available at TTL level, but keep in mind that TTL level is 3.3V.
Well, I connect to the small white one on the board. The strange thing that the other two ports (ttySAC1 and ttySAC2) are working fine, just using the RX and TX pin. The GPS Receiver uses 3.3V TTL level... When I connect to D9 connector using my pc and a terminal I can receive and transmit data. I hope there is still an easy way to use ttl level at ttysac0. Disassembling would took me too long...
hi methez please help me ..i have a question how did you open the
/dev/ttySAC1 file when i use the command open("/dev/ttySAC1",..);
it gives me error saying -> /dev/ttySAC1 : No such file or directory
what may be the problem..i'm using ubuntu
the error is same on both desktop and mini
waiting for generous reply
stuck
hi stuck, are you sure you have an device named "/dev/ttysac1" on your desktop computer? try "cd /dev/" and then "ls". You should then see if you have such an device on your desktop computer. On my desktop comupter the serial devices are naemd "/dev/ttySx"! On the mini device the serial devices are named "/dev/ttySAC0" ... "/dev/ttySAC2" and it works fine opening those ports, except the TTL level connector on ttySAC0. Take a look in the source examples. The "comtest" example does exactly what you are looking for (at least when you are running qtopia)
Mathez, Could you post your code and kernel version for accessing the serial ports. Maybe a mini tutorial for doing this. (ie changing permissions on ports.....) A lot of new programmers up here. Thanks Mike
Hi there, I will post some code later because I'm very busy at the moment... But it would be very generous if someone could solve, or at least give me a hint, to my problem in my initial posting! Many thanks in advance mathez
first of all thanks to MikeB for looking into my problem.
Now, as promised, I will give you a small excerpt of my threaded programm
that I'm running under qtopia.
First I will give you a small overview of the hardware that I'm using on
the serial ports.
On ttySAC1 and ttySAC2 I have connected two GPS receivers and I have a
wireless module that
I wanted to connect to ttySAC0, but (as seen above) I did not manage to get
it working on that port.
Instead I use an USB adapter for this device, so ttyUSB0 is currently that
file...
In my application I have some buttons and I just start the thread calling
the enable() function
when clicking on one of the buttons.
For the sake of clarity I will only post the function where I read (using
interupts) from ttySAC1
and ttySAC2 and store the results in a file. It is just a straight forward
modification of the comtest
example that comes with the mini. I inserted lots of comments, so I think
this code is very easy to understand.
First of all the header file of my GPSThread class:
#ifndef GPSTHREAD_H
#define GPSTHREAD_H
#include "pthread.h"
class GPSThread
public:
GPSThread();
virtual ~GPSThread();
virtual void enable(); // start the thread
virtual void disable(); // stop the thread
bool should_run; // for stopping the thread
bool is_running; // status of the thread
pthread_t thread; // the thread itself
int commA_fd, commB_fd; // the file descriptors of the two serial ports
int deviceSpeed; // the baud rate of the two devices
int byteBits; // the number of bits
// the name of the first port, i.e. "/dev/ttySAC1"
const char *deviceNameA;
// see also the implementation of the constructor
const char *deviceNameB;
pthread_mutex_t mutex; // a mutex, not really needed in this excerpt
#endif // GPSTHREAD_H
Pretty simple so far. Now here is the implemtation of this class.
# include "gps_thread.h"
# include "pthread.h"
# include <stdio.h>
# include <termio.h>
# include <unistd.h>
# include <fcntl.h>
# include <time.h>
# include <string.h>
# include <errno.h>
GPSThread *instance;
void *recorder_function(void*)
// those are my file descriptors for the output files, one for
// each receiver
FILE *fileA_fd, *fileB_fd;
// the struct for the device attributes
struct termios deviceAttr;
// a struct for defining the timeout when using interupt communication
struct timeval timeout;
// the timeout value for the select function, pass NULL for
// no timeout
timeout.tv_sec = 0;
timeout.tv_usec = 50;
// this is just for naming my files with date and time, not
// really needed
time_t rawtime;
struct tm *timeinfo;
char filenameA[80], filenameB[80];
time(&rawtime);
timeinfo = localtime(&rawtime);
// the file names
strftime(filenameA, 80, "/home/GPS_A_%y%m%d_%H%M%S.bin", timeinfo);
strftime(filenameB, 80, "/home/GPS_B_%y%m%d_%H%M%S.bin", timeinfo);
// open the files for writing
fileA_fd = fopen(filenameA, "w");
fileB_fd = fopen(filenameB, "w");
// now it gets interesting:
// here the ttySAC1 is opened
instance->commA_fd = open(instance->deviceNameA, O_RDWR, 0);
if (instance->commA_fd < 0)
printf("Unable to open device\n");
// set the port to non blocking mode
if (fcntl(instance->commA_fd, F_SETFL, O_NONBLOCK) < 0)
printf("Unable set to NONBLOCK mode\n");
// here the ttySAC2 is opened
instance->commB_fd = open(instance->deviceNameB, O_RDWR, 0);
if (instance->commB_fd < 0)
if (fcntl(instance->commB_fd, F_SETFL, O_NONBLOCK) < 0)
// set all the device attributes to zero
memset(&deviceAttr, 0, sizeof(struct termios));
// set the parameters, see the constructor for the values
deviceAttr.c_iflag = IGNPAR;
deviceAttr.c_cflag = instance->deviceSpeed | HUPCL | instance->byteBits
| CREAD | CLOCAL;
deviceAttr.c_cc[VMIN] = 1;
// apply the attributes to ttySAC1
if (tcsetattr(instance->commA_fd, TCSANOW, &deviceAttr) < 0)
printf("Unable to set comm port\n");
// apply the attributes to ttySAC2, they are the same except of the
// device name
if (tcsetattr(instance->commB_fd, TCSANOW, &deviceAttr) < 0)
// my buffer for reading
// I read somewhere that the serial ports have an 64 byte buffer, so I
// alway try to read 64 bytes
// because the port speed is nearly 1Mbps, reading single bytes would be
// quite slow, like in the comtest example
unsigned char buffer[64];
// this is the main loop of the thread, it runs till I stop it
while(instance->should_run)
// this is needed for reading with interrupts
fd_set readSetFD;
// set it to zero
FD_ZERO(&readSetFD);
// add the first device
FD_SET(instance->commA_fd, &readSetFD);
// add the second device
FD_SET(instance->commB_fd, &readSetFD);
// the select function will cause the thread to wait, till data
// is available on one of the ports
# define max(x,y) ( ((x) >= (y)) ? (x) : (y) )
if (select(max(instance->commA_fd, instance->commB_fd) + 1, &readSetFD,
NULL, NULL, &timeout) < 0) {
//printf(strerror(errno));
# undef max
// variable for the number of bytes read
int length;
// is data available on the first device?
if (FD_ISSET(instance->commA_fd, &readSetFD)) {
// if so, read as long as data is available
// this loop will usually only run once
while ( (length = read(instance->commA_fd, buffer, 64)) > 0 )
// and write it to the file
fwrite(buffer, sizeof(char), length, fileA_fd);
fflush(fileA_fd);
// the same as above, but for the second device
if (FD_ISSET(instance->commB_fd, &readSetFD)) {
while ( (length = read(instance->commB_fd, buffer, 64) ) > 0 )
fwrite(buffer, sizeof(char), length, fileB_fd);
fflush(fileA_fd);
// do some cleaning up if the thread was stopped
close(instance->commA_fd);
close(instance->commB_fd);
fclose(fileA_fd);
fclose(fileB_fd);
return NULL;
GPSThread::GPSThread()
// a global variable for accessing the object from the thread function
// this is bad code. it would be better to pass the object as an argument
// to the function
// lazy me :-)
instance = this;
pthread_mutex_init(&mutex,NULL);
is_running = false;
should_run = false;
// sell explaining
deviceSpeed = B921600;
byteBits = CS8;
deviceNameA = "/dev/ttySAC1";
deviceNameB = "/dev/ttySAC2";
GPSThread::~GPSThread()
void GPSThread::enable()
pthread_mutex_lock(&mutex);
should_run = true;
// start the thread
pthread_create(&thread,NULL,recorder_function,NULL);
is_running = true;
pthread_mutex_unlock(&mutex);
void GPSThread::disable()
should_run = false;
// wait for the thread to die
pthread_join(thread,NULL);
is_running = false;
I hope this helped. Threaded programms won't compile that easy, you will
have to make some adjustments to the
configuration files. If you need some help on that, just ask.
kind regards
mathez
Just an addition: I was able to run that programm on my desktop computer, but starting the thread will ever cause the error "No such file or directory" because I don't have two serial ports on my desktop computer and they are named differently to the mini. But on the mini it runs very fine and the threaded approach won't cause the UI to freeze...
Same outcome. I have a ttl rs232 level shifter from sparkfun. i set voltage to 3.3v from gpio and gnd from serial ports then rx/tx null modem and straight nothing. I just wanted to see the same output I see when I plug the cable into the rs232 port from pc. got some odd chars once. but i think it was just noise. i will try this experiment again when my cable kit comes in.
ok!! I spoke too soon. I had the vcc wire on the wrong part of gpio. works now!!! I used 3.3v off outside pin closest to sd card. and gnd from serial ports. now i'm getting the normal console stuff... hope that helps. The ttl serial is 3.3v so my level shifter needed true 3.3v http://www.sparkfun.com/commerce/product_info.php?products_id=133
I think Tx (transmit) from the board is no problem, but Rx because the pin is connected to the max3232 ROUT1 output.
Thanks MikeB, my connection to CON1 was very similar to yours. I also needed 3.3V for my devices but did not get any response. Maybe it is like dec says that the problems are only with the RX pin. I will also try it with a level shifter. But, perhabs, my board is broken... I will see. Thank you all for your suggestions. regards mathez
hi im trying to develop an application by reading the serial port. i compiled the example on my deskotp machine (ubuntu 9.10) executing this instrution: arm-linux-gcc -o comtest comtest.c after that i send the file comtest to the mini2440, and im trying to execute by this instrution: ./comtest but it thows me this mistake: Unable to open device streeror() is no such file or directory can you help me what do i doing wrong? thanks!!
Hallo, I have one question. You have written that you have no problem with ttySAC1 an ttySAC2. I tried to connect my microprocessor(PIC) to both ports and see if I get something on this ports "cat /dev/ttySAC1" but I see nothing. Can you tell me where the problem ? Regards
Janusz: Two things...maybe. 1) The serial ports on the headers expect 3.3v ttl. PIC may be 5v. 2) What serial set up is the mini2440 set for 9600,8,N,1 or 115200,8,N,1.
david: in http://www.friendlyarm.net/forum/topic/963 Stuck apparently fixed this problem i am waiting for his reply of how he did it.
i think that the solution could be changing the code to read the SAC1, i have been reading and it seems to be that SAC0 has problems because its use to configure the sistem what do you think?
friend i have the solution!!!
you have to edit your code: the comtest
look for the line where you configure the port i change this line:
const char *DeviceName = "/dev/ttyS0";
it has to be like this:
const char *DeviceName = "/dev/ttySAC0";
i tested sending info to my ubuntu machine from my mini and it works fine!!
but when i send info from my ubuntu machine to my mini it doesnt work
what could it be?
i solve the half of the problem plese help me with the other part
thanks a lot!!
can any body helpme? i cant send info from my desktop machine to my mini2440 (using the comtest example), but i can send info from my mini to my desktop machine can someone giveme some ideas?
david what type of level shifting are you using. the pc may read down to 3.3 volts. but your mini isnt gonna read full voltage from rs232 from pc.
i have the j2 in 5volts if i change this to 3.3 volts my mini doesnt work,
i found other code that my mini can receive info from my desktop pc but now
i trying to join both codes, im having some troubles
these are both codes:
with this i can send info with my mini to my desktop machine
# include <stdio.h>
# include <stdlib.h>
# include <fcntl.h>
# include <getopt.h>
# include <time.h>
# include <errno.h>
static void Error(const char *Msg)
fprintf (stderr, "%s\n", Msg);
fprintf (stderr, "strerror() is %s\n", strerror(errno));
exit(1);
static void Warning(const char *Msg)
fprintf (stderr, "Warning: %s\n", Msg);
static int SerialSpeed(const char *SpeedString)
int SpeedNumber = atoi(SpeedString);
# define TestSpeed(Speed) if (SpeedNumber == Speed) return B##Speed
TestSpeed(1200);
TestSpeed(2400);
TestSpeed(4800);
TestSpeed(9600);
TestSpeed(19200);
TestSpeed(38400);
TestSpeed(57600);
TestSpeed(115200);
TestSpeed(230400);
Error("Bad speed");
return -1;
static void PrintUsage(void)
fprintf(stderr, "comtest - interactive program of comm port\n");
fprintf(stderr, "press [ESC] 3 times to quit\n\n");
fprintf(stderr, "Usage: comtest [-d device] [-t tty] [-s speed] [-7]
[-c] [-x] [-o] [-h]\n");
fprintf(stderr, " -7 7 bit\n");
fprintf(stderr, " -x hex mode\n");
fprintf(stderr, " -o output to stdout too\n");
fprintf(stderr, " -c stdout output use color\n");
fprintf(stderr, " -h print this help\n");
exit(-1);
static inline void WaitFdWriteable(int Fd)
fd_set WriteSetFD;
FD_ZERO(&WriteSetFD);
FD_SET(Fd, &WriteSetFD);
if (select(Fd + 1, NULL, &WriteSetFD, NULL, NULL) < 0) {
Error(strerror(errno));
int main(int argc, char **argv)
int CommFd, TtyFd;
struct termios TtyAttr;
struct termios BackupTtyAttr;
int DeviceSpeed = B115200;
int TtySpeed = B115200;
int ByteBits = CS8;
const char *TtyName = "/dev/tty";
int OutputHex = 0;
int OutputToStdout = 0;
int UseColor = 0;
opterr = 0;
for (;;) {
int c = getopt(argc, argv, "d:s:t:7xoch");
if (c == -1)
break;
switch(c) {
case 'd':
DeviceName = optarg;
break;
case 't':
TtyName = optarg;
break;
case 's':
if (optarg[0] == 'd') {
DeviceSpeed = SerialSpeed(optarg + 1);
} else if (optarg[0] == 't') {
TtySpeed = SerialSpeed(optarg + 1);
} else
TtySpeed = DeviceSpeed = SerialSpeed(optarg);
break;
case 'o':
OutputToStdout = 1;
break;
case '7':
ByteBits = CS7;
break;
case 'x':
OutputHex = 1;
break;
case 'c':
UseColor = 1;
break;
case '?':
case 'h':
default:
PrintUsage();
if (optind != argc)
PrintUsage();
CommFd = open(DeviceName, O_RDWR, 0);
if (CommFd < 0)
Error("Unable to open device");
if (fcntl(CommFd, F_SETFL, O_NONBLOCK) < 0)
Error("Unable set to NONBLOCK mode");
memset(&TtyAttr, 0, sizeof(struct termios));
TtyAttr.c_iflag = IGNPAR;
TtyAttr.c_cflag = DeviceSpeed | HUPCL | ByteBits | CREAD | CLOCAL;
TtyAttr.c_cc[VMIN] = 1;
if (tcsetattr(CommFd, TCSANOW, &TtyAttr) < 0)
Warning("Unable to set comm port");
TtyFd = open(TtyName, O_RDWR | O_NDELAY, 0);
if (TtyFd < 0)
Error("Unable to open tty");
TtyAttr.c_cflag = TtySpeed | HUPCL | ByteBits | CREAD | CLOCAL;
if (tcgetattr(TtyFd, &BackupTtyAttr) < 0)
Error("Unable to get tty");
if (tcsetattr(TtyFd, TCSANOW, &TtyAttr) < 0)
Error("Unable to set tty");
for (;;) {
unsigned char Char = 0;
fd_set ReadSetFD;
void OutputStdChar(FILE *File) {
char Buffer[10];
int Len = sprintf(Buffer, OutputHex ? "%.2X " : "%c", Char);
fwrite(Buffer, 1, Len, File);
FD_ZERO(&ReadSetFD);
FD_SET(CommFd, &ReadSetFD);
FD_SET( TtyFd, &ReadSetFD);
if (select(max(CommFd, TtyFd) + 1, &ReadSetFD, NULL, NULL, NULL) < 0) {
# undef max
if (FD_ISSET(CommFd, &ReadSetFD)) {
while (read(CommFd, &Char, 1) == 1) {
WaitFdWriteable(TtyFd);
if (write(TtyFd, &Char, 1) < 0) {
if (OutputToStdout) {
if (UseColor)
fwrite("\x1b[01;34m", 1, 8, stdout);
OutputStdChar(stdout);
if (UseColor)
fwrite("\x1b[00m", 1, 8, stdout);
fflush(stdout);
if (FD_ISSET(TtyFd, &ReadSetFD)) {
while (read(TtyFd, &Char, 1) == 1) {
static int EscKeyCount = 0;
static int x = 0;
WaitFdWriteable(CommFd);
if (write(CommFd, &Char, 1) < 0) {
if (UseColor)
fwrite("\x1b[01;31m", 1, 8, stderr);
OutputStdChar(stderr);
if (UseColor)
fwrite("\x1b[00m", 1, 8, stderr);
fflush(stderr);
if (Char == 'x') {
x ++;
if (x >= 3)
printf("prueba felipe\n");
} else
x = 0;
if (Char == '\x1b') {
EscKeyCount ++;
if (EscKeyCount >= 3)
goto ExitLabel;
} else
EscKeyCount = 0;
return 0;
ExitLabel:
if (tcsetattr(TtyFd, TCSANOW, &BackupTtyAttr) < 0)
return 0;
AND WITH THIS I CAN RECIEVE INFO WITH MY MINI
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <termios.h>
#include <stdio.h>
/* la tasa de baudios esta definida en <asm/termbits.h>, que esta
incluida <termios.h> */
#define BAUDRATE B38400
/* cambie esta definicion por el puerto correcto */
#define MODEMDEVICE "/dev/ttyS1"
#define _POSIX_SOURCE 1 /* fuentes cumple POSIX */
#define FALSE 0
#define TRUE 1
volatile int STOP=FALSE;
main()
int fd,c, res;
struct termios oldtio,newtio;
char buf[255];
Abre el dispositivo modem para lectura y escritura y no como
controlador
tty porque no queremos que nos mate si el ruido de la linea envia
un CTRL-C.
fd = open(MODEMDEVICE, O_RDWR | O_NOCTTY );
if (fd <0) { perror(MODEMDEVICE); exit(-1); }
tcgetattr(fd,&oldtio); /* almacenamos la configuracion actual del puerto
bzero(newtio, sizeof(newtio)); /* limpiamos struct para recibir los
nuevos parametros del puerto */
BAUDRATE: Fija la tasa bps. Podria tambien usar cfsetispeed y
cfsetospeed.
CRTSCTS : control de flujo de salida por hardware (usado solo si el
cable
tiene todas las lineas necesarias Vea sect. 7 de Serial-HOWTO)
CS8 : 8n1 (8bit,no paridad,1 bit de parada)
CLOCAL : conexion local, sin control de modem
CREAD : activa recepcion de caracteres
newtio.c_cflag = BAUDRATE | CRTSCTS | CS8 | CLOCAL | CREAD;
IGNPAR : ignora los bytes con error de paridad
ICRNL : mapea CR a NL (en otro caso una entrada CR del otro
ordenador
no terminaria la entrada) en otro caso hace un dispositivo en bruto
(sin otro proceso de entrada)
newtio.c_iflag = IGNPAR | ICRNL;
Salida en bruto.
newtio.c_oflag = 0;
ICANON : activa entrada canonica
desactiva todas las funcionalidades del eco, y no envia segnales al
programa
llamador
newtio.c_lflag = ICANON;
inicializa todos los caracteres de control
los valores por defecto se pueden encontrar en
/usr/include/termios.h,
y vienen dadas en los comentarios, pero no los necesitamos aqui
newtio.c_cc[VINTR] = 0; /* Ctrl-c */
newtio.c_cc[VQUIT] = 0; /* Ctrl-\ */
newtio.c_cc[VERASE] = 0; /* del */
newtio.c_cc[VKILL] = 0; /* @ */
newtio.c_cc[VEOF] = 4; /* Ctrl-d */
newtio.c_cc[VTIME] = 0; /* temporizador entre caracter, no usado
newtio.c_cc[VMIN] = 1; /* bloqu.lectura hasta llegada de
caracter. 1 */
newtio.c_cc[VSWTC] = 0; /* '\0' */
newtio.c_cc[VSTART] = 0; /* Ctrl-q */
newtio.c_cc[VSTOP] = 0; /* Ctrl-s */
newtio.c_cc[VSUSP] = 0; /* Ctrl-z */
newtio.c_cc[VEOL] = 0; /* '\0' */
newtio.c_cc[VREPRINT] = 0; /* Ctrl-r */
newtio.c_cc[VDISCARD] = 0; /* Ctrl-u */
newtio.c_cc[VWERASE] = 0; /* Ctrl-w */
newtio.c_cc[VLNEXT] = 0; /* Ctrl-v */
newtio.c_cc[VEOL2] = 0; /* '\0' */
ahora limpiamos la linea del modem y activamos la configuracion del
puerto
tcflush(fd, TCIFLUSH);
tcsetattr(fd,TCSANOW,&newtio);
configuracion del terminal rea...stripped-down
I SEND THE SECOND CODE AGAIN:
#include <fcntl.h>
#include <stdio.h>
#define FALSE 0
#define TRUE 1
main()
int fd,c, res;
char buf[255];
controlador
un CTRL-C.
cfsetospeed.
cable
ordenador
Salida en bruto.
newtio.c_oflag = 0;
programa
llamador
caracter. 1 */
puerto
configuracion del terminal realizada, ahora manejamos las entradas.
En este ejemplo, al introducir una 'z' al inicio de linea terminara
el
programa.
while (STOP==FALSE) { /* bucle hasta condicion de terminar */
bloque de ejecucion de programa hasta que llega un caracter de fin de
linea, incluso si llegan mas de 255 caracteres.
Si el numero de caracteres leidos es menor que el numero de caracteres
disponibles, las siguientes lecturas devolveran los caracteres
restantes.
'res' tomara el valor del numero actual de caracteres leidos.
res = read(fd,buf,255);
buf[res]=0; /* envio de fin de
cadena, a fin de poder usar printf */
printf(":%s:%d\n", buf, res);
if (buf[0]=='z') STOP=TRUE;
/* restaura la anterior configuracion del puerto */
tcsetattr(fd,TCSANOW,&oldtio);
I THINK THAT THE MISTAKE IN THE FIRST CODE COULD BE IN THIS PLACE:
if (UseColor)
if (UseColor)
fflush(stdout);
BUT HOW CAN I JOIN BOTH CODES? HELPPPP!!
THANKS
Hey David, how is it going? Why do you want to join both codes? I have tried the first code and I can send and receive info bidirectionally from my mini. Best regards.
Hi, I am Gayatri i am working on friendlyarm micro2440 board after connecting GPS module to ttysac1 or ttysac2 i cant see whether it is working or not. please tell me how to check the GPS module to send the data to PC.
Hi David and Pedro, the problem is.. /dev/ttySAC0 is used as a terminal, so all the streaming received in that port will be interpreted like a command for the kernel, besides, David are you from Colombia?, if you are, can you give me your e-mail?
Hello people, Also see this:- http://www.friendlyarm.net/forum/topic/2638 I am having similar kind of problem with /dev/ttySAC[0-2] except /dev/ttyUSB0
