I have a micro2440-128M, and there is /dev/mtd0 (bootloader), mtd1 (kernel), mtd2(yaffs2), and mtd3(whole NAND flash). When I try to read any of the mtd device (mtd0, mtd1 ,etc), either using "cat" directly or using the mtd_debug read tool, I would get a lot of "uncorrectable error". The device itself works fine. Has any of you got mtd-utils working on a 128M mini/micro 2440 board with friendlyarm kernel and roofs? I know you can use bootloader to do some of the flash work, but I would like to be able to upgrade kernel and bootloader within a booted system. Your help is appreciated.
