Hello folks, 1) I'm intending to power my mini via a 6V battery power. Any problems ? From what I saw the regulators can handle that easily, but my concern is related to the LCD (mine is a T35). 2) I'm also intending to run a custom board (from my last project's incarnation) that needs about 250 mA / 3.3V - so, albeit the 3.3 regulator can source 800 mA, andahammer's faq states that at peak mini2440 uses 600 mA, and that puts me a little over the edge. I'm biased towards an external regulator, but if I can avoid an extra hw... Thanks for your time :)
6v source + 250 mA / 3.3V drain
Max voltage rating on LCD 5.5 or 5.6V. The datasheet is on the front page. I wouldn't put 6V on mine as I don't want to take the chance of blowing it up, but for you . . . Does that quoted 600mA for the 3.3 or the 5V? I think you will find a fair chunk of the input current goes to the LCD. I would measure how much current is really drawn off the 3V3 reg and then make an informed decision. Those regulators probably are current and temperature protected, if not the cost of replacing one of those is small compared to the CPU or LCD. I'd use a separate supply and not muck about with the dev board.
you can drop the 6 vlt battery down by placing 2 silicon diodes in series with the supply line 2 diodes in series will drop about 1.2 vlts
You might be OK with this, if the battery voltage was a constant 6V. I found my board dropped out at about 4.7 Volts. The other problem is that a 6Volt (Lithium?) battery when fully charged will put out more then 6Volts. Diodes may not help in this case. Look at the nominal discharge voltage rating for your pack. Maybe, a 1Amp 5V LDO could do the job if your battery voltage doesn't go below about 5.5Volts.
