Hi, I'm struggling to get the DSUB-9 port of the Mini2440 working. A few questions: - Is the WINCE BSP configured for the first serial port as serial debug port? - If yes, can it be disabled without recompiling the CE image? - Anybody using a reasonable COM port test tool? - The Serial Assistant bundled with the board is Chinese only. Is there a translation or En version for this? Thanks in advance LB
COM1 Serial Port under Win CE
It should be pretty straight forward. You will have to use the COM Port with the port name in the following format "ASRL1::INSTR". This is for DUSB-9. Unlike windows it does not use names as COM1, COM2 etc..
