Hello
somebody already attempt to use OpenNETCF with CE6? I am trying to use it
but without positive results. at the same time when use CE5 works
perfectly, somebody already knows or had some experience with this DLL an
example of the code that does not work in CE6 and that if it works in CE5
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using OpenNETCF;
using OpenNETCF.IO;
namespace gpio_cf1
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
private void textBox1_TextChanged(object sender, EventArgs e)
private void button1_Click(object sender, EventArgs e)
OpenNETCF.IO.PhysicalAddressPointer pap = new
OpenNETCF.IO.PhysicalAddressPointer(0x56000000, 32);
textBox1.Text = "" + (uint)pap.ReadInt32();
it is simple as soon as I am trying to read the value of an internal
registry.
this diagnosis for the case,!!!!
System.ArgumentNullException was unhandled
Message="ArgumentNullException"
StackTrace:
at System.Runtime.InteropServices.Marshal.ReadInt32Internal()
at System.Runtime.InteropServices.Marshal.ReadInt32()
at OpenNETCF.IO.PhysicalAddressPointer.ReadInt32()
at gpio_cf1.Form1.button1_Click()
at System.Windows.Forms.Control.OnClick()
at System.Windows.Forms.Button.OnClick()
at System.Windows.Forms.ButtonBase.WnProc()
at System.Windows.Forms.Control._InternalWnProc()
at Microsoft.AGL.Forms.EVL.EnterMainLoop()
at System.Windows.Forms.Application.Run()
at gpio_cf1.Program.Main()
InnerException:
I repeat, in CE5.0 works perfectly. not thus in CE6.0
some idea?
OpenNETCF & CE¨6 ??
Windows CE 6.0 has a different security model and VirtualAlloc to a physical address is no longer allowed. Since this is what the PhysicalAddressPointer class relies on to work, it causes the class to fail. The only workaround is to create an actual driver for the device that exposes a method to do the memory-mapping for you. ------------------------ OpenNETCF Support Team OpenNETCF Consulting e: support@opennetcf.com w: http://www.opennetcf.com/ ------------------------
