hi guys i have a formatted my sd card with ext3 fs. now i am having trouble mounting it on the mini2440? It says no valid FAT filesystem found on mmcblk0. has anyone tried this before? thanks in advance rose
SDCARD
As far as i know you have use an ext3 fs enabled kernel image to mount it succesfully. You can config your kernel with ext3 support and try again.
Hallo, there are two things: first: support for ext3 is not included in standard kernel. You have to compile your own one with support for ext3 enabled. This should not a problem. second: The auto mounter does not mount SD cards which have other file systems than vfat. A line in /etc/init.d/rcS can this do at least at system start. Or edit /etc/mdev.conf and let your own scrit run at the insert event of your SD card. skip
thanks skip for the mention.m kinda new to linux i saw the rcS and mdev files bt dont know what to put 'xactly. Can u help me on that? thanks in advance
