I install the lasted Qtopia 2.2.0 128 MB image. But when I booting from NAND I've a blank screen, and no output to serial. If I boot from NORD I've supervivi and I can press B for boot, and all are ok. Where is the problem, why the image can't boot directely from NAND ? Thanks
NAND boot failed, but ok with NORD
I have the exact same problem, I've just installed a new kernel (zImage- trying to active GPIO sys classes)with no change on bootloader and system file image. system boots correctly via serial port but dose not work manually...
