Hi everyone, Here is my build of wince with English language. It's version 6.0, not 6.0 R3 because I have not installed it yet :D http://www.mediafire.com/?sharekey=4ed29227c49592aeab1eab3e9fa335ca92e3b...
My English build of wince 6.0
Hi caolang, I have downloaded the nboot and nk.bin file shared by you. when i try to port the image into my FriendlyArm mini2440, it works fine in NOR mode. Once i closed the dnw and switch the NOR and again boot the system, it is not booting properly. It hangs after completing nearly 90% of booting process. what could be the problem. Can you please help me solve this issue. thanks in advance
@Sriram it seems that you have a old board or i think old version of Supervivi you should update the SuperVIVI using Jtag......
great. After updating the supervivi via JTAG, the image is working well... Now, the problem is when i connect the device with my PC, it ask for a driver. I'm unable to connect it with active sync. Can you please help me to get this driver and solve the active sync problem.
Hello All, I have same problem with booting. I have a Mini2440-128M board. Could you help how can use the Jtag. I have a small board with JTAG-MINI label. It has a 10pin connector to Jtag and 25pin male connector. The 25pin connector is use to paralell port? How can I programming or where can I found the the newest Supervivi? Regards, Labi
