Nothing happens when conntecting an SD card or a usb flash drive in Qutopia. Do I have to enable this somewhere? Thanks Fred,
Qutopia does not recognize USB or SD.
Nope. Mine worked out of the box. Go into terminal do a <ls>, then plug in the SD card and wait a few seconds then do another <ls>. You should now see that unit appear in your directory list. And they should stay there.
Thanks, tried that but it still does not appear. Then I tried cardctl eject, and go the message; cardctl not found. Got any clue? I am getting rather frustrated with the whole card now..
in /dev do you see usbdev1.1_ep00 or perhaps a variation on that? You could try <dmesg> You are going to get a bucket load of information, but I see my USB hub and heaps of usb stuff in there. There could be other commands to determine what is is "connected", as I am not much more than a beginner.
Thanks Davef, you certainly are much less of a beginner than I am :) I did find the usb drive with <dmesg> but it did not show up anywhere else. Found a 1gb flash drive this morning, and voilą, it showed up at once. Strange?
