Hi, i need to find a way to remove the taskbar/menu at the bottom of the screen of windows ce, when looking in the source of the solutions builder, i can see that there a option of autohide and ontop, when i create the entry in the registry it does not do anything, it seem stuck on top all the time any help would be greatly apreciated thanks in advance
Need to find a way to remove the task bar at the bottom
If you choose on your device Settings -> taskbar you can disable "always on top". Taskbar will disappear then when running a full screen application.
Ok, it make more that 40hours i was trying to find this, look at the sources of wince,try in visua studio to write my hide taskbar, try to build a version wince that would have done that and it was in my face already there i believe that i always try to take the super long run instead of the quick one so in short thank you very very very, much you solve my problem in 2 sec thanks again
