Hello I have a mini2440 and I have the question. Is there a way to run php and sql (or MySQL). It would be good for me if I had a database and a way to manage it. Even if there is not php sql (or it is too much for the board) is there another database i can use? Thanks for help Byte
php sql
A fellow worker is playing with Cherokee on a Linux PC, prior to cross-compiling it for the mini2440 dev board. He says it can run PHP, but don't know about MySQL. Might be worth a look.
hi i tried to install cherokee but i couldnt did it because this messenge show in my screen: no acceptable C compiler found in $PATH See `config.log' for more details. I have been reading and i have to install gcc or tell the mini where its but i dont have any idea, and what i find in internet dont helpme please any idea how can i install this thanks
Hi i downloaded it but when i was extracting a lot of mistakes appearsme, what can i do? there is another source where i can downloadit or that archive cant extract? how can i install it? How made your friend to install cherokee? Help me please!
He has written a script to do it via NFS. I plan to modify his script, test it and then write a procedure probably towards the end of next week . . . or the week after. Dave
hi i have already install the compiller The arm-linux-gcc-4.3.2
but now what? how can i make the cross compilacion and install this
webserver in my mini2440?
im using ubuntu 9.10
thanks
Andres, I have managed to compile Cherokee using this script, BUT have not tried to run it on the platform. No idea of whether it works or not. Have a go and lets see what problems you turn up next. Good luck! Add the file extension .sh
forgiveme but i dont know how can i use it?, where should i add and how? i have been trying installing buildroot to make the crosscompiling but im so lose,i installed it but i don have idea how to use it. heelp! and thanks for the help you have bring me
Andres, Take the file I sent and add the extension .sh For some reason I couldn't attach a file that had the extension .sh on it. So, you will have a file called <dave_mini2440-bootstrap-cherokee.sh> Place this in your home folder on the linux host machine and then using your terminal navigate to where you placed the file and: sudo ./dave_mini2440-bootstrap-cherokee.sh> then your password This process is called executing a script. Read through the script and you will see where the output is placed. You will have to read through the documentation on the Cherokee site for insight into how to set up and run Cherokee. Why do you want to run Cherokee? Is Boa, which is in the factory distro, not capable enough for you? The books link seems to be missing on the Wiki. Search for <Building Embedded Linux Systems.pdf> on the internet. I don't use buildroot. I would suggest you read how to compile programs in the above book, Chapter 4 and section 4.2
Dave i do what you toldme copy the archive to my home directory and put .sh in his name but when i execute your instruccion appearsme this messenge: sudo: ./dave_mini2440-bootstrap-cherokee.sh: command not found if you have problems to save with that extension why dont you modificate one archive that already have this extension and save (obviosly make a respald of that archive) i have made this and its works me, but with another type of extension. this night im gonna read what you suggestme and tell you, why dont boa server? because its too week for what we need. ok thanks for your help
I am running Ubuntu 9.04 and it worked OK. Maybe the #!/bin/bash needs to
be:
#!/bin/sh or #!/bin/ash on your machine. I assume you need to use sudo on
your linux host to access the root directory.
Failing that just type in each line manually, hit enter at the end of each
command. Each export command will stay in force as long as you keep the
terminal session open.
DEST=~/mini2440-bootstrap
export ac_cv_func_malloc_0_nonnull=yes
export ac_cv_func_realloc_0_nonnull=yes
export ac_cv_func_shm_open=no
export ac_cv_lib_rt_shm_open=no
export CROSS_COMPILE=arm-none-linux-gnueabi-
export CC=${CROSS_COMPILE}"gcc"
export CXX=${CROSS_COMPILE}"g++"
export AR=${CROSS_COMPILE}"ar"
export AS=${CROSS_COMPILE}"as"
export RANLIB=${CROSS_COMPILE}"ranlib"
export LD=${CROSS_COMPILE}"ld"
export STRIP=${CROSS_COMPILE}"strip"
export PATH=$PATH:/home/davef/mini2440-bootstrap/../
NMAKE=4
cd ${DEST}/cherokee-0.99.44/
echo " ****************** Configuring Cherokee ********************* "
make distclean
./configure --localstatedir=/var \
--exec-prefix=${DEST}/output/cherokee \
--prefix=/home/cherokee \
--with-wwwroot=/www \
--enable-static-module=all \
--enable-shared=no \
--enable-static \
--disable-pam \
--disable-ipv6 \
--disable-tls \
--disable-largefile \
--host=arm-linux \
--target=arm-linux \
LDFLAGS="-s -lcrypt -lpthread -ldl
-L/home/davef/mini2440-bootstrap/arm-2008q3/arm-none-linux-gnueabi/linc/armv4t/l
ib"
CFLAGS="-march=armv4t -mtune=arm920t -Os"
make -j4 LDFLAGS="-all-static"
make install
You do know that \ means just continue typing. I would copy and save the
whole part that starts with .configure all the way down to -Os" as you
don't want to type that whole command more than once!
Have a go.
Hi then do i write this in my console terminal of my desktop pc? (in this moment im not in my office i can do the test now) making this will be cherokee running in my mini 2440? this path ? what is it this path for? i know i have to change it but first i need to know that. export PATH=$PATH:/home/davef/mini2440-bootstrap/../ thanks for your help forgive my (maybe) simple doubts but im a beginner thanks again.
Yes. Yes, this will cross-compile Cherokee to run on your mini2440. In this case <Path> tells the computer where your working directory is. Usually <PATH> is used to tell the computer where your compiler and compiler tools are located. Yes, you have to change it for your personal directory setup. You should find your executable files in /mini2440-bootstrap/cherokee-0.99.44/ somewhere. I haven't done any more then this.
the compiler its where i download the ARM-Linux GCC 4.3.2 or where i installit?? friend parce (in my country parce meants a good friend) thank you im gonna check it tomorrow at first hour and i tell you if its works its gonna be wonderful i going to be in doubt with you add my msn andrewt12357@hotmail.com may be i could you return the favor thanks friend
Where ever you extracted the 4.3.2 to. Serial port? There are many ways to download your program to the FRiendlyArm platform. Serial is not one that I would use. I just copy the program to a USB flashdrive, stick it into the USB port and copy it across to my file system. If you are doing a lot of development then NFS seems more appropriate. Honestly, I think you need to do a few months of reading and playing around with, say compiling a hello.c or flash a LED or something, so that you become familiar with the Linux system. I would STRONGLY suggest you tackle some of the basics and wait for a tutorial to be written about what you want to do. There are going to be many more problems ahead of you.
hi again
i want to tell you the steps what i made (for find some mistakes)
i do what you said: copy this code in the main console, i change the path
for the place where the compiler is, this was the changes:
export PATH=$PATH:/home/felipe/mini2440-bootstrap/../ HERE
NMAKE=4
pushd .
make distclean
--enable-static \
--disable-pam \
--disable-ipv6 \
--disable-tls \
--host=arm-linux \
LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440-
bootstrap/arm-2008q3/arm-none-linux-gnueabi/linc/armv4t/lib"
AND HERE
make install
popd
it was necessary to leave and space at the end of the text to run the
archive.
to execute it i made it step in this directory
root@felipe-desktop:/home/felipe/cherokee-0.99.44#
its created me a carpet mini2440-bootstrap in root directory.
inside this carpet i found this: bin lib sbin
is it really what suppose to be created?
i copy this file to mini2440
but how can i execute this files?
i tried by difrerents comands but i cannt doit
HELP ME PLEASE we almost finish
thanks for all your help
Almost finished! I doubt it. However, I am at work so will not get a chance to look at this until tonight. I do not remember finding bin lib sbin in my mini2440-bootstrap directory. The files you are looking for are: cherokee cherokee-worker cherokee-admin The one, I think, you want is cherokee-worker. About 3Mb. I believe you then just copy this file to, for example, /home on the FriendlyArm and in the terminal application navigate to where cherokee-worker is located and type <cherokee> You also need to place cherokee.conf in another diectory called /etc/cherokee I will have another play with it this evening (New Zealand time). Does <carpet> = folder? Dave
yes carpet = folder jejeje (forgive my bad english)
archive=files
and yes "bin lib sbin" these are folders.
inside bin i found this archives: cget, cherokee-config cherokee-panic
cherokee-tweak
inside lib this :
brltty libattr.so.1.1.0
libcrypto.so.0.9.8 libgcrypt.so.11.5.2 libncursesw.so.5.7
libnss_nis.so.2 libproc-3.2.8.so libsysfs.so.2.0.1
libx86.so.1
cpp libblkid.so.1
libcrypt.so.1 libglib-2.0.so.0 libnsl-2.10.1.so
libnss_winbind.so.2 libpthread-2.10.1.so libthread_db-1.0.so
libxtables.so.2
dbus-1.0 libblkid.so.1.1.0 libc.so.6
libglib-2.0.so.0.2200.3 libnsl.so.1
libnss_wins.so.2 libpthread.so.0 libthread_db.so.1
libxtables.so.2.0.0
firmware libbrlapi.so.0.5
libdbus-1.so.3 libgpg-error.so.0 libnss_compat-2.10.1.so
libntfs-3g.so.54 libreadline.so.5 libtic.so.5
libz.so.1
i486 libbrlapi.so.0.5.3
libdbus-1.so.3.4.0 libgpg-error.so.0.4.0 libnss_compat.so.2
libntfs-3g.so.54.0.0 libreadline.so.5.2 libtic.so.5.7
libz.so.1.2.3.3
i586 libBrokenLocale-2.10.1.so
libdevmapper.so.1.02.1 libhistory.so.5 libnss_dns-2.10.1.so
libpamc.so.0 libreadline.so.6 libticw.so.5
linux-sound-base
i686 libBrokenLocale.so.1
libdl-2.10.1.so libhistory.so.5.2 libnss_dns.so.2
libpamc.so.0.82.1 libreadline.so.6.0 libticw.so.5.7 lsb
init libbsd.so.0 libdl.so.2
libhistory.so.6 libnss_files-2.10.1.so
libpam_misc.so.0 libresolv-2.10.1.so libudev.so.0
modules
klibc-IVI64Rw9vcD2pCELnFiJgX5AtWY.so libbsd.so.0.1.4
libe2p.so.2 libhistory.so.6.0 libnss_files.so.2
libpam_misc.so.0.82.0 libresolv.so.2 libudev.so.0.5.0
security
ld-2.10.1.so libbz2.so.1
libe2p.so.2.3 libiptc.so.0 libnss_hesiod-2.10.1.so
libpam.so.0 librt-2.10.1.so libulockmgr.so.1
terminfo
ld-linux.so.2 libbz2.so.1.0
libexpat.so.1 libiptc.so.0.0.0 libnss_hesiod.so.2
libpam.so.0.82.1 librt.so.1 libulockmgr.so.1.0.1 tls
libacl.so.1 libbz2.so.1.0.4
libexpat.so.1.5.2 libiw.so.29 libnss_mdns4_minimal.so.2
libparted-1.8.so.12 libSegFault.so libusb-0.1.so.4 udev
libacl.so.1.1.0 libc-2.10.1.so
libexpatw.so.1 libkeyutils-1.2.so libnss_mdns4.so.2
libparted-1.8.so.12.0.0 libselinux.so.1 libusb-0.1.so.4.4.4 ufw
libanl-2.10.1.so libcap.so.2
libexpatw.so.1.5.2 libkeyutils.so.1 libnss_mdns6_minimal.so.2
libpcprofile.so libsepol.so.1 libusplash.so.0
xtables
libanl.so.1 libcap.so.2.16
libext2fs.so.2 libm-2.10.1.so libnss_mdns6.so.2
libpcre.so.3 libslang.so.2 libutil-2.10.1.so
libatasmart.so.4 libcidn-2.10.1.so
libext2fs.so.2.4 libmemusage.so libnss_mdns_minimal.so.2
libpcre.so.3.12.1 libslang.so.2.1.4 libutil.so.1
libatasmart.so.4.0.2 libcidn.so.1
libfuse.so.2 libm.so.6 libnss_mdns.so.2
libpcsclite.so.1 libssl.so.0.9.8 libuuid.so.1
libatm.so.1 libcom_err.so.2
libfuse.so.2.7.4 libncurses.so.5 libnss_nis-2.10.1.so
libpcsclite.so.1.0.0 libss.so.2 libuuid.so.1.3.0
libatm.so.1.0.0 libcom_err.so.2.1
libgcc_s.so.1 libncurses.so.5.7 libnss_nisplus-2.10.1.so
libpopt.so.0 libss.so.2.0 libwrap.so.0
libattr.so.1 libcrypt-2.10.1.so
libgcrypt.so.11 libncursesw.so.5 libnss_nisplus.so.2
libpopt.so.0.0.0 libsysfs.so.2 libwrap.so.0.7.6
and inside sbin:
cherokee cherokee-admin cherokee-worker
THE ARCHIVES WE NEED!!
i did what you tellme put a cherokee-worker in home
and create a file in /etc name cherokee there i put this files
cherokee cherokee-admin and cherokee.conf
after that i went to /home and wrote the command cherokee (in console)
but appearsme this:
-/bin/sh: cherokee: not found
also tried typing:
./cherokee
what should i do now?
what have i to do with the other files? (i only copy this files in the
2440)
thanks!!!
hi , help please to finish these , while i would like to learn more about this, there are another links where i can find some info? or how should i look for in google, again thanks for all your help
Still at work! Forget about the files in lib, you have done a static compilation. I would not put cherokee-admin in /etc/cherokee . . . but I can't tell you where to put it! There is a relationship between cherokee and cherokee-worker that I do not fully understand. I was told one was a "wrapper" for the main executable. The Cherokee website has some documentation on using these files which seem to say that you "just need to call one or other" and "don't call one of them unless you are doing development". Now your: ./cherokee -/bin/sh: cherokee: not found Check cherokee.conf and see where it expects to find the main executable and the cherokee.conf files. I might have more answers in 2-3 hours.
*** Check cherokee.conf and see where it expects to find the main executable and the cherokee.conf files. *** Probably, should say: Check cherokee.conf and see where it expects to find the cherokee.conf file. Problems with: /bin/sh Think there was another thread that talked about this issue. I assume you are using the distro version of BusyBox.
Home from work. Now, I see in <cherokee-conf> not cherokee.conf there is a line that says: exec_prefix=/home/user/mini2440-bootstrap/output/cherokee Try making a directory by that name on the FriendlyArm and drop your three executables in there. Appears to be a problem with the script. Check that cherokee-conf is in home/cherokee
I copied the entire contents of /mini2440-bootstrap/output/cherokee to /home/cherokee on the FriendlyArm. Don't move or change anything, if I suggested to do that before. The whole folder is 14M, which only leaves 6M of storage on the factory distro 2.6.32.2 with pictures and videos removed. My /mini2440-bootstrap/output/cherokee/lib is very different to yours. I have only 8 files: libcherokee-base.a libcherokee-base.la libcherokee-client.a libcherokee-client.la libcherokee-config.a libcherokee-config.la libcherokee-server.a libcherokee-server.la and two directories: cherokee (with nothing in it) pkconfig (with one file cherokee.pc) In /mini2440-bootstrap/output/cherokee/sbin do: file cherokee file cherokee-worker file cherokee-admin and ensure they say: ELF 32-bit LSB executable, ARM, version 1 (SYSN), statically linked, for GNU/Linux 2.6.14, not stripped When I try to run the program I get <Illegal instruction>. I will talk to my parce about how to get this program running . . . tomorrow.
hi /mini2440-bootstrap/output/cheroke folder inside are found *bin folder this folder has this files inside: cget, cherokee-config, cherokee-panic, cherokee-tweak *lib this has: -cherokee (is a folder) empty (as you) -pkgconfig(folder) with a file cherokee.pc and this files: (they are not than as a copy before i made a mistake) -libcherokee-base.a -libcherokee.base.la -libcherokee-client.a -libcherokee-client.la -libcherokee-config.a -libcherokee-configa.la -libcherokee-server.a -libcherokee-server.la *sbin has: -cherokee -cherokee-admin -cherokee-worker we have the same folders with the same files! then should i copy the entere folder: mini2440-bootstrap/output/cherokee/ to /home of my mini2440? how can install cherooke? im going to read what you tellme above installing the compiler arm i made following the steps of this link, this page also has some examples of hellow word, is it what you tellme above that i should study? http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-... thanks
Good morning. Did you do: file cherokee as I suggested above? I was suggesting that you do a few tutorials to gain confidence in tackling something like getting Cherokee to run on your platform. I suspect that there are still a few problems with the script. If I go to the /home directory on my Linux host pc I see a directory called /cherokee In it there are three folders etc include share Looking at the dates they appear to be the result of the cross-compilation. Also, if I go to the root directory on the Linux host pc I see another directory called /www In it there some images. These also were generated at the same time. At first I thought these were the result of installing Cherokee on the host but I now I think these folders need to be included into what is copied to the target. Here is the latest suggestion from my friend . . . **** The cherokee.conf is always stored in /installed folder/cherokee/etc. Hence, if you specified prefix=/home/cherokee (in the script), you will need to copy the /home/cherokee to target's /etc folder. At target, go to /etc/cherokee/sbin and run cherokee which will look for /etc/cherokee/etc/cherokee/cherokee.conf. **** I think there is another problem here as there is no /etc/cherokee/sbin on my traget. sbin is at /home/cherokee I asked him if this is correct. Hope to have more answers in about 4 hours.
ensure that the files cherokee, cherokee-admin and cherokee-worker say: ELF 32-bit LSB executable, ARM, version 1 (SYSN), statically linked, for GNU/Linux 2.6.14, not stripped. i couldnt do it because when i tryed to open it with gedit appears me this message: "Compruebe que no está intentando abrir un archivo binario." "check you are not trying to open a binary file". how can i modify this files then? about the script i think the mistake could be in this line: --disable-tls \ when we are configuring the cherokee the right line shouldnt be this? --disable-nls then what files should i copy to the mini2440? is it everything found in: mini2440-bootstrap/output/cheroke how can i execute it? friend thanks a lot
hi i made this: i copy the folder cherokee to home folder in mini2440 (this folder has inside bin, lib, sbin with all the files) and in the folder /etc in mini2440 made a folder cherokee with this files: cherokee, cherokee.conf step in /etc/cherokee executed the command ./cherokee but appears me this: Ilegal instruccion. I dont know if i understand succesful what youre friend told us to do so what should i do? thanks
hi again jejej i tried to check your doubt: "think there is another problem here as there is no /etc/cherokee/sbin on my traget. sbin is at /home/cherokee I asked him if this is correct." so i move the folder sbin from home/cherokee (on mini2440) to /etc/cherokee after that again try with this command ./cherokee but the result was the same ilegall instruccion
I wasn't asking you to modify any files.
You are only checking that those files have been cross-compiled and are
static.
Why do you think --disable-tls should be -disable-nls?
OK, some feedback from my friend . . .
seems there should be lots of files in lib
He has Cherokee working on an ARM9 in-house platform, so I think we only
need to get the script correct or ??
What size are your cherokee cherokee-worker and cherokee-admin files?
i think that this line shoulbe in this way for what i found in this link http://www.cherokee-project.com/doc/basics_installation_unix.html in advance parameters, and i look for more configuration writing help and i didnt find anything with tls, the line most similar i found was that the folder sbin side is:6.2Mb cherokee: 596,3 KiB cherokee-worker: 2.8mb cherokee-admin: 2,8 MiB yes couldbe the script, i hope your friend could send it to you I think we most try with that script and maybe if we dont have success i suggest that you ask to your friend the files that was generete with that script
Evidently, in the folder where you did the compilation do: .configure -h or --h and you will see lots more switches that you can apply. I will be seeing him about 6PM (8 hours from now) and we are going to sort this issue out. BFN
hi when i made the compilation i was step here: home/felipe/cherokee so i step in this location and executed .configure but this was appearsme .configure -h :command no found and the same with --h im from Colombia and in this moment its 17:41
Friend im so tired im going to sleep now, im in my house so i dont have the mini2440 in this moment, but before that i want to know what should i do tomorow? where do i look for in that file in mini2440 or in my desktop pc and where is this file? what do i do with this? how can we finish the installing cherokee in mini2440 is it wrong script that we use to compile? thanks for all your help
The file in the desktop PC where you extracted cherokee. You just look in the file (using gedit) and you should see what switches or options you really have for configuring cherokee. For example is there really a -disable--tls option. I will have a look in 2 hours and write some notes before I go to bed. I will be sitting with my friend for an hour tonight trying to figure out how to complete the installation and correct the errors in the script.
To re-cap: In your source directory type: sudo ./configure -h and you find all the available options. Note. there is no mention of -disable-tls In your source directory type: gedit INTSALL and you will find a lot more information. I completely cleaned everything out and re-run the script. On the host: Again in /mini2440-bootstrap/output/cherokee there are 3 directories called bin lib sbin. Also, in /home there is a folder called cherokee with directories called etc include share From /home I copied these 3 directories to /mini2440-bootstrap/output/cherokee (need to fix the script). sudo cp -r -a cherokee/etc /home/user/mini2440-bootstrap/output/cherokee sudo cp -r -a cherokee/incude /home/user/mini2440-bootstrap/output/cherokee sudo cp -r -a cherokee/share /home/user/mini2440-bootstrap/output/cherokee The output/cherokee directory is 19M and has 877 items. Andres, my apologies on this line: LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440- bootstrap/arm-2008q3/arm-none-linux-gnueabi/linc/armv4t/lib" It should be: LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440- bootstrap/arm-2008q3/arm-none-linux-gnueabi/libc/lib" (BUT IT DOESN'T MAKE ANY DIFFERNCE, see below) You do have this toolchain (arm-2008q3) in /mini2440-bootstrap? Now, I didn't need to make any changes to my script so after re-compilation and putting it on the target, of course, I get the same result <Illegal instruction> The only differences between my friend's toolchain and mine are: - he is using a much older kernel version and - he has a different library setup (he has his toolchain in /usr/arm) As I was curious why your incorrect LDFLAGS line would even compile I put an non-existent folder name in my LDFLAGS line and re-compiled. I noticed a message saying that if a cross-compiler was available then it would use it. Which brings me to another issue: - in my .profile file (on the host)I have a line: EXPORT PATH=/home/user/mini2440-bootstrap/arm-2008q3/bin:$PATH You must do this as your files say they are cross-compiled. I will get a copy of his files and run them on my dev board tomorrow night. I have seen it running on his ARM platform so I know someone can do it:)
hi again about this: "You do have this toolchain (arm-2008q3) in /mini2440-bootstrap? " i didnt have this folder until the compilation was made. do i have to download this toolchain? where i get it? when i was styding your script i understand about LDFLAGS but i didnt understand why did you call this line i only install ARM-Linux GCC 4.3.2 thanks
As mentioned above: during compilation "I noticed a message saying that if a cross-compiler was available then it would use it." You must have a path in your .profile or bashrc which says: EXPORT PATH=/path/to/your/cross/compiler/bin:$PATH and that part in LDFLAGS is ignored. So, you use the 4.3.2 toolchain. That is OK. You can now appreciate the difficulties in even getting a simple script to work for more than one person. For example, those first four lines: export ac_cv_func_malloc_0_nonnull=yes export ac_cv_func_realloc_0_nonnull=yes export ac_cv_func_shm_open=no export ac_cv_lib_rt_shm_open=no mean nothing to me, I have to accept that they are needed. Now, something I did question and will now try are these lines: --host=arm-linux --target=arm-linux I thought host would be <i386> and target arm-none-linux-gnueabi. At least they shouldn't be the same. I will investigate.
when i was install the compiler the guide i use for it tell me this: sudo gedit /etc/bash.bashrc (and add this line: PATH=$PATH:/usr/local/arm/4.3.2/bin) so should i change this line export PATH=$PATH:/home/felipe/mini2440-bootstrap/../ for this one export PATH=$PATH: right? and if thats ok then this line is gonna change too, isnt it? LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440-bootstrap/arm-2008q3/arm-none-linux-gnueabi/linc/armv4t/ lib" for this LDFLAGS="-s -lcrypt -lpthread -ldl -L/usr/local/arm/4.3.2/bin-none-linux-gnueabi/linc/armv4t/lib" i want to be sure about this this is the link that i use to install it http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-... thanks
excuse me i made a mistake, i reply to you my messeage when i was install the compiler the guide i use for it tell me this: sudo gedit /etc/bash.bashrc (and add this line: PATH=$PATH:/usr/local/arm/4.3.2/bin) so should i change this line export PATH=$PATH:/home/felipe/mini2440-bootstrap/../ for this one export PATH=$PATH:/usr/local/arm/4.3.2/bin right? and if thats ok then this line is gonna change too, isnt it? LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440-bootstrap/arm-2008q3/arm-none-linux-gnueabi/linc/armv4t/ lib" for this LDFLAGS="-s -lcrypt -lpthread -ldl -L/usr/local/arm/4.3.2/bin-none-linux-gnueabi/linc/armv4t/lib" i want to be sure about this this is the link that i use to install it http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-... thanks
You have missed some important information I have been trying to tell you. 1. The line LDFLAGS is incorrect there is no ../linc/armv4t/lib see corrected line above. *** LDFLAGS="-s -lcrypt -lpthread -ldl -L/home/felipe/mini2440- bootstrap/arm-2008q3/arm-none-linux-gnueabi/libc/lib" *** 2. This part of LDFLAGS appears to be ignored. export PATH=$PATH:/home/felipe/mini2440-bootstrap/../ I don't know what this line even does in the script. The most important thing is the source being cross-compiled. It appears to be. In bash.bashrc you need to use the path to your toolchain . . . export PATH=$PATH:/usr/local/arm/4.3.2/bin would be correct if that is where you extracted 4.3.2 I am going to talk to another guy about the script.
ok i dint made that change before because you tellme it didnt change anything, but ok i understand, then this night will you work on this with your friend who already make running cherokee in mini2440?
After a one hour conservation with a OpenEmbedded/script guru he has basically told me that I am "really trying to do things the hard way" He says, "I should get a bigger Linux PC and use OpenEmbedded" and "stop hitting my head against a brick wall". OpenEmbedded has a Cherokee project. I will get the files from my friend and try running them on the mini2440. Don't hold your breath!
I was told <Illegal instruction> probably means there are compiled for the an incorrect machine/architecture.
Then yours friend advice is change mini2440 and work with another pc? but what is it the other Embedded tecnollogy that already works with cherokee? is it a normal computer of 32 bits?
Just in case you can install *deb packages cherokee compiled for armel can be downloaded from here: http://packages.debian.org/lenny/cherokee
Go to OpenEmbedded and they have a Cherokee project listed. http://cgit.openembedded.org/cgit.cgi/openembedded/tree/recipes/cherokee My friend's advice is to stop doing these projects from "scratch" and learn how to use OpenEmbedded. My other friend is staying learn to do it the hard way. I need to take a poll. From what I understand, if you do NOT need to know how to fix things when they go wrong than use OpenEmbedded. There is good support on existing OpenEmbedded projects. You have another " learning curve", but perhaps a more useful development system. Are you doing this as a hobby or work? Evidently, for OpenEmbedded you need a BIG Linux box and probably broadband. Thanks jm2222 for yet another toolset to learn :) Running Cherokee on a PC is pretty straight-forward. In fact <apt-get install cherokee> (Ubuntu) does it, I think.
Andres,
There was a problem in the script. There needs to be a \ at the end of the
LDFLAGS lines before CFLAGS.
Well, this time I get much smaller files and doing:
cherokee 603827
cherokee-admin 1233199
cherokee-worker 1230919
readelf -a cherokee
and at the bottom of the terminal output it says that it is now compiled
for the v4t, which our machine is. So looking better.
Copied to the dev board and the <Illegal instruction> message has
disappeared, but now there is another problem:
<corrupted double-linked list>
Off to find a fix for that one.
New script:
#!/bin/bash
export PATH=$PATH:/home/user/mini2440-bootstrap/arm-2008q3/bin
NMAKE=4
pushd .
make distclean
--enable-static \
--disable-pam \
--disable-ipv6 \
--disable-tls \
--host=arm-linux \
LDFLAGS="-s -lcrypt -lpthread -ldl \
-L/home/davef/mini2440-bootstrap/arm-2008q3/ \
arm-none-linux-gnueabi/libc/lib" \
make install
popd
jaaja ok friend thanks alot , did you really made a poll, i want to know too more opinions about this.
before i start to my compiling i want to know 2 things
1. Did you really erase the folders that was create with the last compiling
i refer of www and cherokee-0.99.44 folders both located in /
and i would like to copy the script again but with my path compiler:
#!/bin/bash
export PATH=$PATH:/usr/local/arm/4.3.2/bin #this is the route of mi path
NMAKE=4 #compiler i see it in bash.bashrc
pushd .
make distclean
--enable-static \
--disable-pam \
--disable-ipv6 \
--disable-tls \
--host=arm-linux \
-L/usr/local/arm/4.3.2/bin \ #i change it, is it ok
arm-none-linux-gnueabi/libc/lib" \ #or should i only
#change davef for felipe
make install
popd
friend thanks a lot
It was a long evening. My friend sent me his cherokee files and I got the same error as with my files. Your script looks correct to me. I expect that when you do: readelf -a cherokee you will see at the bottom of the terminal output: File attributes: Tag_CPU_name: "4T" Tag_CPU_arch: v4T This is a good sign. However, I also expect that when you try to run it you will get: <corrupted double-linked list> We could NOT find a solution for this. When my friend tries to run cherokee on his mini2440 dev board maybe we will make more progress!
in another topic they say its posible to install debin in it, but has it graphical environment, may be it could be the solution, and with the apt-get make a good and easy solution. what do you know about that?
hi why dont you ask to your friend to send you his compiles folders (its not script) and try to install it?
My friend is coming around tomorrow night and we are going to try to sort this out on one Linux box/mini2440 dev board combination. Ask again in a few days if you don't heard back from me.
hi friend, i wanted to start again, and when i install the compiller i realize of this: felipe@felipe-desktop:/opt/FriendlyARM/mini2440/examples/comtest$ arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /scratch/julian/lite-respin/linux/src/gcc-4.3/configure --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=arm-none-linux-gnueabi --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-symvers=gnu --enable-__cxa_atexit --with-pkgversion='Sourcery G++ Lite 2008q3-72' --with-bugurl=https://support.codesourcery.com/GNUToolchain/ --disable-nls --prefix=/opt/codesourcery --with-sysroot=/opt/codesourcery/arm-none-linux-gnueabi/libc --with-build-sysroot=/scratch/julian/lite-respin/linux/install/arm-none-linux-gn ueabi/libc --with-gmp=/scratch/julian/lite-respin/linux/obj/host-libs-2008q3-72-arm-none-li nux-gnueabi-i686-pc-linux-gnu/usr --with-mpfr=/scratch/julian/lite-respin/linux/obj/host-libs-2008q3-72-arm-none-l inux-gnueabi-i686-pc-linux-gnu/usr --disable-libgomp --enable-poison-system-directories --with-build-time-tools=/scratch/julian/lite-respin/linux/install/arm-none-linux -gnueabi/bin --with-build-time-tools=/scratch/julian/lite-respin/linux/install/arm-none-linux -gnueabi/bin Thread model: posix gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) this is how its configure, i think it most be important to see, some mistake in our script, i hope this could help us!! bye
