can anybody tellme how do i log as a root in the terminal, is the only way i see to install new programs, but i need the permission. help me please
help me please
but when im trying to install a program its appear a messenge permission denied. i give permission with the command chmod 777 and when i write ls-l the archive seems have all permissions -rwxrwxrwx the first - i think that it is because it and executable im not sure. help me please
Think you had better tell us what program you are trying to install on what and a printout of the EXACT error message.
im trying to install abyss web server, and im executing the command ./abyss, in the carpet bin i create the dictory abyss web server, when i execute that command the mistake is this: /bin/sh: ./: permission denied. im following a tutorial in internet to install this program in linux but im no sure if the dictory where i install is bin, i think i should install it in etc because there is install the programs i hope you can help me bye
I don't think it is normal to place programs in /etc. I believe they normally go in /usr/bin. You can run a program from anywhere if you have a path to it or you execute it directly from where it is located. On the host do: sudo ./abyss On the target just do: abyss Perhaps ./abyss should work as well. Make sure there is no space after the / There are 482,000 hits on Google for "permission denied"
today i tried to install the abyss in a pc with ubuntu, but i had the same problem, so i think that the problem its not for 2440, but i need to install some progrmas,i heard about sycronize mini2440 with a desktop pc, but i look for it and cant find how. can you help how to sycronize or install new programas in the mini2440, i need to install php and web server, please help!! thanks to every body very good the foros
This is just a stab in the dark, as i'm more WinCE, but have you tried: chmod +777 abyss or: chmod a+x abyss Both commands set execute rights for all users, i just don't know which flavour mini2440 use. you can also try: chown abyss This makes sure that you own it. Thank you, Errol
hi i install the abyss succesfull in ubuntu and i realize of this:
when i write this command in ubuntu i do in this way
./abyssws but when i do it in mini2440 appears this mistake: syntax error
"(" unexpected, so i write it in this way ./ abyssws and then appears the
same mistake you dont have permissions. check the space between / and
abyssws.
help me please!!! what should i do
i think that the solution could be upgrating the kernel,but how i install it? i followed the instruccion of the manuals here but when i tried with version like 2.6.29 y extract the archives and im no sure what i have to do there are so many documents which one should i select in the program dnw? could be this the solution help me!!
hi felipe, your line /bin/sh: ./: permission denied. let me assume you start an script and these script tryes to execute any thing like ./$PROGNAME where $PROGNAME is empty. ./ is a directory which cannot executed and the error message therefor is permission denied. skip
that mistake appears when you says but when i place in the righ carpet
(inside abyssws) and write ./abyssws the messege is this syntax error: "("
unexpected, how can i resolve this
help me please
your error looks like a syntax error in a script. look at the first line of the script, which interpreter is used? sh is not bash and bash is not ksh.... even the syntax of these shells is mainly identical, there exists subtil differences. on your host, you have all types of shell but on the mini is only busybox that emulates the shell. it's seams you have to fix the shell script to running in busybox. skip
i think that you are right the mistake can be for this reason, but how can i fix it?? any idea or link where i can find information, im looking too, but its very dificullt forme
hi im trying to install a diferent web server this time its cherokee, but when im install it appears this mistake: no acceptable C compiler found in $PATH See `config.log' for more details. I have been reading and i have to install gcc or tell the mini where its but i dont have any idea, and what i find in internet dont helpme please any idea how can i install this helpp!!! jejeje thanks to every body
