Did the following to run my standalone application on QT, without loading "/bin/qtopia". Using mini2440 with kernel 2.6.32 and QT 2.2.0. 1. Edit "/etc/init.d/rcS" - Commented "/bin/qtopia &" - inserted paths and exports as below export QPEDIR=/opt/Qtopia export QTDIR=/opt/Qtopia export PATH=$QPEDIR/bin:$PATH export LD_LIBRARY_PATH=/opt/Qtopia/lib:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH - Inserted following to execute my application $QPEDIR/bin/trial -qws & 2. Saved "/etc/init.d/rcS" and then rebooted mini2440. 3. Now the display shows the screen as desired. But nothing happens when I tried to click any icons. 4. This happens even if I replace "trial" with any other application (like filebrowser) supplied with mini2440. 5. Application "trial" works when clicked from desktop on mini2440, when "/bin/qtopia &" is not commented "$QPEDIR/bin/trial -qws &" is not inserted in the "rcS" file. I am unable to understand why the touchpad is not working. Please help. Thanks & best regards Satish
Running standalone QT application
Satk I configure my mini2440 to use the tslib and put the following in /etc/profile export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/dev/input/event0 export TSLIB_CALIBFILE=/usr/local/tslib/etc/pointercal export TSLIB_CONFFILE=/usr/local/tslib/etc/ts.conf export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export QWS_MOUSE_PROTO=tslib:/dev/input/event0 This works for me. flux000
Hi all I'd like to make standalone applications. I execute sample programs like Satk. (kernel and qt version are same.) The difference is only application program. I used simple sample program "hello" or tutorial "t1". I made sure that they work well on qtopia. But I couldn't see anything on LCD. Do I need specific code in standalone application? Does anyone have advices? Thank you. Tatsuya.
