Hi guys, I have prepared an application successfully using a QListView class in x86-qtopia using qt2 designer. My application gets compiled successfully but gives segmentation fault when i run the application. What must be the problem?
Segmentation fault
do rebuild all files, linking of object files from non up to date moc's can cause segmentation fault. skip
I prepared a small application for testing using a QListView. I drew
ListView widget on my form which i named ListView and named ny UI file as
myapp_base.ui.
In my header file i wrote-
#ifndef MYAPP_H
#define MYAPP_H
#include "myapp_base.h"
class MyApp : public MyAppBase
public:
MyApp(QWidget *parent=0,const char *name=0, WFlags fl=0);
~MyApp();
My implementation file is following-
#include "myapp.h"
#include <qlistview.h>
MyApp::MyApp(QWidget *parent, const char *name,WFlags fl):
MyAppBase(parent,name,fl)
QListViewItem *newItem;
newItem->setText(0,"newItem");
ListView->insertItem(newItem);
MyApp::~MyApp()
And my main file is-
#include "myapp.h"
#include <qapplication.h>
int main(int argc, char *argv[])
QApplication app(argc,argv);
MyApp *obj;
obj->show();
return app.exec();
My code gets compiled successfully but gives a runtime segmentation fault.
What is the problem??
MyApp *obj;
obj->show();
change to :
MyApp obj;
obj.show();
or
MyApp *obj = new MyApp();
obj->show();
Ok, But then when i wrote main like this-
#include "myapp.h"
MyApp obj;
obj.show();
return app.exec();
It gave me following error-
error main.cpp.7.there is no call for MyApp::MyApp()
candidates for the call are MyApp::MyApp(QWidget *parent,const char *name,
WFlags fl);
candidates to the call are MyApp::MyApp(const MyApp&);
Also when i tried this..
MyApp obj=new MyApp;
or
MyApp obj= new MyApp();
or
MyApp obj=new MyApp(ListView,"myapp");
it gave the same error!!!!
what to do???
Dear andromeda, They are talking x86-qtopia application, not arm-qtopia application. There is no need to put the application to target board with ftp! Thanks Eddy
Got it guys... The problem wasn't in main() but was in implementation....I was declaring pointers without creating objects!!!Now it works fine!!! Thanks!!!
