I followed all of the instructions for downloading a linux image using the latest linux images but now I get a kernel panic Warning: unable to open an initial console. kernel panic not syncing no init found Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Any ideas where I went wrong?
kernal panic missing init ?
Got it! I followed the instructions about 5 times to no avail but then I tried something different. x-partition the drive v-download supervivi k-installed the kernel y- here is the change the instructions say to download root_mizi.img at this point but instead I used root_qtopia.img and this worked fine... Not sure why it worked as I am a complete newbie but thought this might help others.....
Hey guys, i got the same problem! Check your zImage file!! I was using the wrong zImage file and getting the kernel_panic error. My LCD screen is 3.5\" and i was using the 7.0\" image. When i installed the correct zImage it works.
Hi all, Please check your zImage as Eduardo said. If you use correct zImage for LCD it will work. I can't use root_mizi too, but it all work with root_qtopia. BR, Narongrat
I have the same problem with root_mizi. In the manual there is written to download root_default.img but I do not find it. Thanks Davide
I'm having the same problem, I have checked I am using the correct zImage file, but I get the same error message when I use the "root_mizi" file: Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. "root_qtopia" works. Anybody resolved this?
Mizi GUI has a bug in it, either doesnt support the LCDs or it just sucks, QTopia works and seems to have a better development base (QT-embedded) so I'd just stick with it and not worry. But yea that last sync is once you have the hardware interface down and the linux software installed, then you're putting the sort of graphical interface to linux down, and it is having an issue initializing.
