Hello, I'm working on OS WinCE5.0 I'm trying to make recording from mic line and audio in line. I manage to record and process audio data from mic line but I can't record any audio data from audio in line. Is there anything to be done to activate audio in line - any driver or tool? Thanks
audio in line
the audio in port can be seen on the board and on schematics. but not mentioned in manual clearly. Is anyone use audio in line?
You will probably have to look in the source code. I suspect that the mixer is only set up for MIC input. I vaguely remember seeing something about the line in not currently working. probably just driver issue. Thank you, Errol
