Hi, Does anyone have source of tslib which is part of the default image by friendlyarm. The tslib version is libts-0.0.so.0.1.1. If I download it from the tslib project page "svn co svn://svn.berlios.de/tslib/trunk/tslib" and build it the version built is libts-0.0.so.0.1.0 . I built QT 4.6.2 and it runs perfectly well with the default tslib(so.0.1.1) including drag operations but if the tslib(so.0.1.0) is used there the cursor movement is erratic and there is no double click support hence in short not usable. Can anyone help me in locating the friendlyarm version of tslib source tslib(so.0.1.1)? regards --fatbrain
source tslib from friendlyarm
The touch screen library, tslib has been extended to include support for the mini6410. Do you have the source to create the module_raw friendlyarm-ts-input.so, it should just be one source file from plugins directory, without this it is not possible to compile any code against the tslib which uses this module or get the touchscreen working
