If I look at the size of the 2.6.32.2 kernel zImage (for the 64M machine) on the downloads page I find it is 2517028. If I compile the kernel source (without errors) using config_mini2440_n35 the size of zImage is 2058836 and it doesn't work. Is it incorrect to assume I should get the same kernel size (and proper operation) compiling it myself? I would have thought that an unmodified config_mini2440_n35 from FriendlyArm, as found in the kernel source, would give the same result as their zImage_N35. Any ideas about where I am going wrong? Thanks, Dave
2.6.32.2 kernel size?
Hi Dave, eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/boot$ ls -la total 7612 drwxr-xr-x 4 root root 4096 2010-03-23 08:37 . drwxr-xr-x 80 root root 4096 2009-12-03 01:51 .. drwxr-xr-x 2 root root 4096 2009-12-30 02:34 bootp drwxr-xr-x 2 root root 4096 2010-03-23 08:37 compressed -rw-r--r-- 1 root root 40 2009-12-03 01:51 .gitignore -rwxr-xr-x 1 root root 5224032 2010-03-23 08:36 Image -rw-r--r-- 1 root root 130 2010-03-23 08:36 .Image.cmd -rw-r--r-- 1 root root 1274 2009-12-03 01:51 install.sh -rw-r--r-- 1 root root 3118 2009-12-03 01:51 Makefile -rwxr-xr-x 1 root root 2516996 2010-03-23 08:37 zImage -rw-r--r-- 1 root root 157 2010-03-23 08:37 .zImage.cmd eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/boot$ My own compiled kernel have 2516996 using config_mini2440_n35 (attached). It works with no problem. I'm using micro 2440 256mb, supervivi 128m and default rootfs. eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/boot$ arm-linux-g++ --version arm-linux-g++ (Sourcery G++ Lite 2008q3-72) 4.3.2 Copyright (C) 2008 Free Software Foundation, Inc. Compiled with gcc 4.3.2. It's not the same result, but very close. hope it helps.
Edurado, Thank you for the listing of your boot directory. I started again with clean a kernel extraction and this time got: 5240416 for the Image and 2517880 for the zImage. Closer, I'll try it and see if it works. I see that your config-mini2440_n35 is unmodified. The fact you are using a different machine should make not difference to the kernel size. Did you do the: arm-linux-g++ while you are in the boot directory? I got "command not found". What happens when you do the following in your boot directory: readelf -a zImage Did you find your USB? Thanks, Dave
Hi Dave, My kernel was downloaded from download section (http://www.friendlyarm.net/downloads). But I think that this 1mb difference won't change the kernel behavior too much (i hope... :S). When I "readelf -a zImage" I got the following: eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/boot$ readelf -a zImage readelf: Error: Unable to seek to 0xea000002 for section headers readelf: Error: Not an ELF file - it has the wrong magic bytes at the start eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/boot$ I did "arm-linux-g++ --version" on my boot directory. I was showing you my arm-linux-g++/gcc compiler version. And I found my usb dir!! Thanks for ask. :D In fact I had found them some time ago, the problem was on fxload. I was following the wrong trail... Take a look: http://www.friendlyarm.net/forum/topic/794?lang=en Now it works perfectly. Regards
Good, we get the same printout for zImage. I thought it would be a ELF file, but obviously I thought wrong! You must have your directories or paths set up different than me as I can't see my arm-linux-g++ version from my boot directory. I will investigate this to ensure that I am compiling against the correct tools. I still find it odd that with the same config file and the same toolchain that we end up with different file sizes. I will ask our ARM kernel guru. Cheers, Dave
It's really strange... if you discover, please share it with me. I forgot to say that arm-linux-g++ is linked on my /usr/bin dir. So I can use it from everywhere. Take a look: eduardo@eduardo-desktop:/usr/bin$ ls -la | grep arm-linux lrwxrwxrwx 1 root root 50 2009-10-23 15:44 arm-linux-ar -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-ar lrwxrwxrwx 1 root root 51 2009-10-23 15:42 arm-linux-g++ -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-c++ lrwxrwxrwx 1 root root 51 2009-10-23 15:43 arm-linux-gcc -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc lrwxrwxrwx 1 root root 50 2009-10-23 15:43 arm-linux-ld -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-ld lrwxrwxrwx 1 root root 50 2009-10-23 15:59 arm-linux-nm -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-nm lrwxrwxrwx 1 root root 55 2009-10-23 16:58 arm-linux-objcopy -> /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-objcopy eduardo@eduardo-desktop:/usr/bin$ regards
"Even using the same machine, config, toolchain -- same everything -- recompile the kernel twice or thrice, and you'll get "probably" different sizes. Ideally it would tend to be smaller with more iterations... but it's not an ideal world." And that is from a ARM kernel guru. I have kept my toolchains separate from /usr/bin, so that explains why I don't see my arm-linux-g++ version from "everywhere". I'll test my new kernel tonight.
