Hello, We purchased the WIFI USB module and was wondering how to use it in WINCE5.0. I have connected it to the USB port but how can we connect to the internet using it? Thanks.
WIFI Wireless USB Module
Hello, Which USB Wifi module have you purchased (model)? If you got the drivers for CE 5.0 with it, then include or copy them to the device and plug it in the usb... Good day, b
Boštjan , When I plug the USB Wi-Fi dongle to my Mini2440 the VNUWLC41 windows opens but it do not find any wireless network. I had try to add networks manually but it don't work. I try on different places (different wi-fi networks) and it do not find any network. I'm using CE 5.0 and my Wifi dongle is the VNT6656AU Can you help me with this???
Hello Bostjan, I have purchased "VIA VT6656" USB WIFI. I am not sure if WINCE5.0 drivers are already present in the image. When I plug it, WINCE does not ask for any drivers. However, I am not sure where to check if it has installed correctly and working.
Hi, i have a wifi usb module of encore, but i don´t know how i connect the module in my mini2440. I haven´t the module´s driver for wince, only drivers to winxp.
Hello, Boštjan , I have found the same issue with CE 5.0 where it will not find any networks using VT6656. I tried in my CE 6.0 arm and it worked fine and found all networks in same environment. Therefore I conclude its with CE 5.0. I need to work on CE 5.0 due to software conflictions. If the driver wasn't there it would come up with the new hardware install wizard. Anyone any ideas? Cheers, Z
